Phillips1795
VCDS - How To Guides - MK3 Leon 5F
Giuseppe Busso
Ioannis
Jan 29, 2021
89
53
Greece
Does anyone knows what this fault is?
Address 5F: Information Electr. Labels: 5F0-035-MIB-STD2.clb
Control Module Part Number: 5QA 035 824 B HW: 5QA 035 824 B
Component and/or Version: MU-S--ER H41 0479
Software Coding: 04738000D70A00001111000100080A002F0101D401A0050002
Work Shop Code: WSC 03743 444 00001
ASAM Dataset: EV_MUStd6C1TSAT 001015 (SE37)
ROD: EV_MUStd6C1TSAT_SK25.rod
VCID: 3F8DF6FBA67DB57E2A-806A
1 Fault Found:
5688 - Control Head for Mulimedia System
B13C9 F2 [008] - On/Off Switch
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 152
Mileage: 45601 km
Date: 2022.12.04
Time: 17:28:53
Voltage terminal 30: 14.3 V
Walone
1,565
432
Near Heathrow
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 152
Mileage: 45601 km
Date: 2022.12.04
Time: 17:28:53
Does the fault come back after you have cleared it?
Jan 14, 2023
Romania
Hello to all! I made a modification to the footwell led lights: I added a new cable to the car hardness that lets me put 2 lights, 1 front and 1 back.
The care came with led light only for the front seats.
Now I have the error below. Is there a way to fix the error? An adjustment with VCDS?
0531 - Footwell Illumination
B11FF 01 [009] - Electrical Failure
Fault Priority: 6
Fault Frequency: 1
Terminal 15 status: On
Terminal 50 status: OFF
Apr 17, 2022
7
Hello,
tried this on 2018 FR and doesn't seems to work (no difference)
SEAT LEON 5F - SLOW Dimming Daytime Running Lights
Leuchte2SL VLB10-Lichtfunktion E 2 - Blinken Links aktiv (Beide Phasen); Auf-und Abdimmend mit P_t_blinken_rampe
Leuchte2SL VLB10-Lichtfunktion F 2 - Blinken Links aktiv (Beide Phasen); Auf-und Abdimmend mit P_t_blinken_rampe
Leuchte2SL VLB10-Dimmwert EF 2 und "Neuer Wert" auf 35 ändern
Leuchte2SL VLB10-Dimmrichtung EF 2 und "Neuer Wert" auf Verkleinern ändern.
Leuchte3SL VLB21-Lichtfunktion E 3 - Blinken Rechts aktiv (Beide Phasen); Auf-und Abdimmend mit P_t_blinken_rampe
Leuchte3SL VLB21-Lichtfunktion F 3 - Blinken Rechts aktiv (Beide Phasen); Auf-und Abdimmend mit P_t_blinken_rampe
Leuchte3SL VLB21-Dimmwert EF 3 - 35
Leuchte3SL VRB21-Dimmrichtung EF 3 – Verkleinern
Anyone tried this on 2017+ Leon ? thank's
tracktoy
403
290
Hello,
on my 2014 car I have
15 - Leuchte2SL VLB10
16 - Lichtfunktion E2 - (Change value to Blinken Links aktiv (Beide Phasen); Auf- und Abdimmend mit p_t_blinken_rampe)
17 - Dimmwert EF2 - (Change value to 35)
18 - Dimming direction EF2 - (Change value to Minimize)
19 - Leuchte3SL VLB21
20 - Lichtfunktion E3 - (Change value to Blinken Links aktiv (Beide Phasen); Auf- und Abdimmend mit p_t_blinken_rampe)
21 - Dimmwert EF3 - (Change value to 35)
22 - Dimming direction EF3 - (Change value to Minimize)
The difference being F2 and F3 i have as nicht aktiv
Mar 9, 2024
Hello friends, I have a 2016 model year seat leon fr vehicle. It has Mib1 unit, retrofit seat sound, rear view camera. I made a mistake today. I was going to make a carbon background on the MIB1 unit with my clone vcds cable, but something went wrong. The appearance of the menus has changed. The subwoofer menu has disappeared. The car photo that appears when you enter the vehicle status menu is no longer there. Before doing these operations, I scanned the vcds. The relevant long code When I copy it back and apply, it seems to accept the code, but there is no change on the tape screen. I wonder where I might be doing wrong. How can I restore the system? Thank you in advance for your help.
Walone
1,565
432
Near Heathrow
2016 MY should have MIB2 unit from factory, at least in the UK it does.
