Well it might be worth slackening your rear control bush bolts, and tighten them back up with the hubs at the height they'd be when on the ground.
I do that with the Mercedes I work on after a bush replacement as when you tighten them up when they've not any weight on them they upset the natural geometry and put its out of spec. 9/10 I've done that the alignment is in the "safe" range.
