Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Alhambra
Alhambra Use this forum for Alhambra specific topics
Reply
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 20-03-2008, 12:25   #1
Chickslips
Posts: n/a
Unhappy Front Windscreen Wipers have stopped working
My front windcreen wipers have stopped working. They went very slow and then have now decided to stop altogether.
I have found a recall notice on the internet but dont know when that was for but any ideas as the cost of repairing this car when things go wrong is crippling me
Many thanks
A
Old 20-03-2008, 14:44   #2
fredt
waster
fredt's Avatar
fredt has 10 points
sounds like the wiper spindles have seized in the shafts? you can try removing the wiper mech and removing the wiper spindles from the shafts and cleaning them up and relubing them, either that or buy a new wiper mech off ebay and see how you get on?
__________________
you aint seen me! right
fredt is offline   Reply With Quote
Old 20-03-2008, 14:56   #3
Jonesy
Leftie and Proud
Jonesy's Avatar
Jonesy has 10 points
Had a simaler problem with my Leon a while back
http://www.seatcupra.net/forums/show...t=wipers+worky
turned out to be what they described as a seized linkage in the end
Jonesy is offline   Reply With Quote
Old 20-03-2008, 15:40   #4
Fl@pper
Cruising with the 6 Pot..
Fl@pper's Avatar
Location: Easy life Cruise control with 200bhp of Bavarian RWD slushboxed Leather Comfort :)
Fl@pper has 10 points
disconnect the motor arm and you can check both the motor for operation and the linkage for smoothness
lift wipers up first though as they will need a hefty push by hand
wiper motor giving up is a fairly common alhambra fault
__________________
Fl@pper SouthernPikeyBigEaredHotRoddingIronMaidenMetallicaFan@e-parts.co.uk
Fl@pper is offline   Reply With Quote
Old 07-01-2009, 10:36   #5
slim jim
Posts: n/a
What has caused my front wipers to stop working.The strange thing being the back wiper runs when I pull the stalk for the front wash wipe? 1.9TDI, 2004, STYLANCE 130BHP. If I fiddle around with the stalk the front wipers come on but there is no rythem or rime, & even when they come on its only for a few seconds and then dead again and no water spraying out for front & back. H E L P !!!!
Old 07-01-2009, 10:38   #6
slim jim
Posts: n/a
Seat alhambra 1.9tdi, 2004, stylance 130bhp
Old 11-01-2009, 13:26   #7
toadleg
Posts: n/a
Your problem is a central control unit for the wipers having gone faulty...
I think ( memory!) on that model , that it is situated centrally under the dash - but a call to Seat parts would tell you that for sure.
The problem here is that its not a diy repair - it has to be fitted by the dealer and then set up by the diagnostic equipment to program it to the car... its the way these things are going Im afraid.
There is just one thing you could try - that is, disconnect the battery for a half hour and see if that cures it / its a reset , just the same as resetting a computer - because thats what it is and this can often work.. you will need to renter your radio code sometimes after that procedure so be aware of that.
WHen you disconnect the battery - hold the terminals of the battery leads ( not the battery) together for five mins... this clears the memory properly...and then reconnect after the half hour.. Hopefully that will work for you --if not, you will need to give your local dealer a ring Monday...
I Sincerely hope I have helped you
Old 15-01-2009, 19:11   #8
samy2009
Posts: n/a
for slimjim,
i have same model 04 , 130 bhp, i've been everywhere, spent lot money for silly things,silly advises, till the end i went to seat dealer, the prob sorted in 5 mn,
look at the fuse box for the wiper and washer fuses, change them even if they look fine to you, before you do that, disconnect the batterie, mine working fine now,
toadleg gave you good idea as well you can try it ,if it didn't work.
by the way for 2 fuses and diagnostic with seat dealer cost me £80
Old 15-01-2009, 22:46   #9
greengiant
Posts: n/a
Many thanks
A
Hi Chickslips,
As already mentioned, the spindles seize, this is a common problem. sometimes you can remove the complete frame assembly and then remove and free off the spindles, but 9/10 its worth bitting the bullet an replace the whole frame. Not very cheap if my memory serves me correctly.
Hope you get it sorted.
Jochen.
Old 15-01-2009, 23:06   #10
F2 Stu
I. Am. Legend.
F2 Stu's Avatar
F2 Stu has 10 points
Seized linkage - it happend on ours.
__________________
2004 VW Passat TDi PD130 Highline Estate
F2 Stu is offline   Reply With Quote
Old 18-01-2009, 14:19   #11
celladogg
Posts: n/a
i had this problem aswell today and found one of the cables leading to th battery had been severed reconected it and all working properly again. hope this could be of help to you...
celladogg
Old 18-01-2009, 23:29   #12
Black TDI Turbo
Shussssh Its A Diesel ...
Black TDI Turbo's Avatar
Black TDI Turbo has 10 points
Wiper linkage has probs seized same as a ford galaxy which are common for it, there crap, if u can get them apart clean lubricate and rebuild they will most probably go again soon. Worth a try tho as they are a fortune to replace.
__________________
Black TDI Turbo is offline   Reply With Quote
Old 19-01-2009, 20:39   #13
90landrover
90landrover has 10 points
Took mine apart four years ago, cleaned and coated the shafts with coppa grease and have had no problems since.
90landrover is offline   Reply With Quote
Old 13-01-2010, 12:22   #14
furiousfingerz
Posts: n/a
Quote:
Hi Slimjim- I've got exactly the same problem with my Alhambra- Did any of these remedies fix the problem, or was it an expensive trip to the Seat delaer?
Old 09-02-2012, 18:01   #15
John Upton
Posts: n/a
Smile
Don't ask me why, but the fault is with fuse 33, it is marked with a fan, although the interior fan was working perfectly well in my case. Symptoms are the front wipers and wash don't work at all, if you pull the lever to get the screen wash, no wash motor runs but the back wiper cycles. You can intermittently get the front wipers to cycle once if you put the lever up to the 'wipers on' position and GENTLY pull the lever towards you.
Fuse 33 is a 10A fuse marked on the list with a fan. Swapped mine and everything is fine now. Thanks to the VW forum for this answer, saved me a fortune.
Old 11-02-2012, 14:42   #16
TheShaggyDA
Posts: n/a
Just wanted to add a thanks, I had the same symptoms (02 Alhambra 1.9TDI SE) - tried the front wiper, the rear would go. The fuses for the wipers were fine, but swapped them anyway - no joy. Found the fuse for the for the headlamp washer had blown, changed that, still nothing. Found this thread, checked fuse 33 - also blown, changed that, success :-)
Old 12-02-2012, 12:03   #17
cupraboy125
Posts: n/a
Seized linkage for sure, best of luck
Old 12-12-2012, 14:31   #18
hugie
Newbie
hugie has 10 points
Just had the same problem with the wipers, Changed the 10a fuse to the fan (33) all works fine Big Thanks.
hugie is offline   Reply With Quote
Old 13-12-2012, 00:04   #19
jasonpe
Posts: n/a
Check Recall
Just a thought. warrantyguide co uk /vehicle-recall-809C45CB488ECE7F80256BB90026955E-seat-alhambra-recall. Will let you fill in the dots
Old 24-02-2013, 21:02   #20
Snowflake
Snowflake has 10 points
Smile
The wiper on my car was out when i bought it (got it cheaper ). Fixed it, this is what i did.
1. Removed the the linkage from the car. Somwhat of a fiddle but i slidd it out sideways kind of.
what happened now was that a discovered that somtime in the past, someone, had removed the linkage and the wiper motor, but lost the cover for the circutboard.
Then solved this by... using a plastic stripe to hold the board in place and just disregard the fact that the circutboard was now in contact with the enviroments.
2. Disconnected the motor from the linkage and then reconnected it to the car to confirm, and yes, it was dead.
3. Since i had the linkage out i greased them upp anyway. First removed, gresed and reconnected all the plastic joints from/to the metalballs. Then removed the actual shafts that transfers the force to the wipers (was one lockingring, a washer and a gasket). Here it was some corrotion.
Fixed this by gently sanding the shafts and using a steel cylinder brush mounted on a drill in the pipes for the shafts. Used a standard steelbrushdisk for a drill to remove other corrotion on linkage.
Observed that there is some holes in the linkage at this shafts that might make it possible to grease them up, still mounted in the car. Removed the central shaft to and regreased.
4. On to the motor.
Removed the circutboard from the motor and cleaned it with some alcohol. The board is to 99% covered in some sort of rubber compound to make it resistant to moisture.
Now i took my magnifyingglas and carfully inspected the board for faults. I found two places where i suspected that the moist had penetrated. This was on the backside, where the central IC is soldered and where the two biggest resistors is soldered.
At the resistors a actualy could see greenich, coppercorrotion. It might have been that the protective compound never covered these points anyhow.
Now i got at small, sharp screwdriver, a pair of tweecers and a sharp blade and VERY CAREFULLY started to remove the compund at and around these sites. It is a fiddly work.
When the compund was gone i again inspected the sites with the magnifyingglass. The IC solding looked ok. But at the resistors the moist had corroded the soldering itself but also the actual coppercircut running in the board so that it no longer connected to the resistors.
I removed corrotion with the blade and then removed the protectiv lackur from the board, making it possible to solder a piece of wire from the circutboard to the resistors. Tested it and found that it was working OK!.
Now only remains to jerryrigg some sort of cover for the circutboard and apply some kind off new protective compound.
//Snowy
Snowflake is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 158
0770chris23, 100andthirty, 90landrover, aaronbromley, adam23, ads_green, Aguilo, AL90, Alexis27, Alhambraguy, Amir, andy.morgan, AndyC567, ArosaRacer, attila_tdi, baba_metca, basssound, BatAndBallMk2, beardo, benzbong, bep, Bigjohn84, bkingb, Black TDI Turbo, blueleontsi, Bowders1, Cinq, cluckfr, Comando, Corvus Cornix, CTID, cupra-tfsi, cuprar265, Dan1.6, dan1990, DannyC87, Dan_bourne, darkhorse, dazescort, Deano2316, dholdi, drooghi, dunjamon, ejarvo, epj1987, F2 Stu, Fl@pper, G-baby158, gav2907, Geordie-Cupra, gieras, Goz, Graham89, GrayT, hpoolsteve, hugie, ianltd, ian_jobson, IBIZA_W1LL, jaggy786, jamie1, jamieFR, Jandro, JasonHughes22, jduggz08, jennpaul09, John Lindsay, Johno247, Jonesy, jreedy, kazand, KeithOT, Kilimanjaro, Lance Uppercut, Law., lbtreecare, Leeoncupra, Lenzman, leon sport, Lewwy, louise ibiza re, Love-Cupra, luciferX, LukeK, Madman0405, magaizeris, MalcB, markmeus, marshey, Martin Lepley, Matt cla, Maximum Bob, McCann87, Mickylad, MiiMii, MJ, Monks Seat, MR OV51LTA, MrS1lly, Muttley, MWG, Nath., nathan_20vt, Neg., Neo, Nick_J, OldNewtown, onesh0t, pingu, POB, purplehaze150, quetzal, racingsquirrel, ragz, rambalad, revdave, Rich, Robley, robreidmotors, roly, ROSSLEY1, rowdyruff, seatleondt1, Seat_Ibiza, Sg76, shaneseat, SheffieldKid, Shepdog, shorn, shortz1975, Slimy, smithy363, smivvy, Snowflake, spen, Steroidas, Stever25, Stevofr184tuned, stezo2k, ste_amd01, Street, strykezero, tcm1106, Temden, terrymcg, Thegedfather, thomasa, Topboy, tractorboy, UncleFester, verbal_kint, Viking, wanderer, wes c/fergus, Wev, Wiggy20, window60, wozza-fr150
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Gauges have stopped working ! jonbentley Leon Mk1 5 14-02-2008 23:52
motor stopped working!! jacko18 Ibiza Mk3 10 13-12-2007 08:29
Thread previews on mouseover stopped working? muddyboots Forum technical problems 8 01-04-2007 10:16
Front and rear fogs stopped working, affects Leon too?? mowgli MK1 & MK2 Toledo 3 08-11-2006 10:18
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
