No power to cluster 6dial 2003 1.9tdi
Ibizatuner1.9
Hi everyone first post. Just bought a 03 6dial with the immobilizer problem. But the dash wasn't lighting up with anything. The LEDs work but nothing else i.e mileometer etc or any lights. So I remove clocks I really solder the pins etc to fix try fix the problems. So next day after soldering plug back in and still the same nothing happening still starts and cuts off and still no dash power atoll. I have a look through fuses. Found one blown replaced it but still the same. Any help appreciated mabey realy causing this??
R3k1355
1,786
251
Yorkshire
Replace the clocks, they're ****.
Sometimes no amount of soldering can save a knackered cluster.
Don't forget to grab the SKC off the old clocks before you bin them.
