Bebe
Hello,
Maybe someone can help me with my problem.
I've got a MY2009 Leon Cupra 2.0 TFSI Revo 2+..
My problem is that sometimes, only when i stay still (750 rpm) or run very slow on the first gear the car overheats. I've got a scan gauge (it reads temperature from OBD) and it reaches 95-100-105 degrees C and the cooling fan's won't start Then i start the defrost function for the windscreen and the water temps drops to normal, 84-87 degrees.
I don't have any error codes, i don't lose coolant, the oil is perfect. I also changed the G62 sensor in the side of the engine, and now i will change the G83 sensor,located on the front of the car near the radiator, on a water hose.
If i drive the car, evan if i race it, it reaches 90-92 degress but then the fan starts and temperature goes down to 81-82-83 degres.
Please help..
*Sorry for my bad english.
Please help..
