Knocking from somewhere
Haze
344
Hey guys
Weekends here again...
Got a slight knocking over small bumps and when I violently turn left to right at slow speeds. Sounds as if it's coming from the the front middle somewhere underneath. It actually sounds like exhaust knocking but from the rear it's firm.
ARBS?
Drop links?
Track rod ends?
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
Time to get dirty mate. Get under there and have a look, only way to find out...cheap
Sent from my Nexus 6 using Tapatalk
verbal_kint
639
31
North West Kent
As Andrewwright says, get under there.
Check the coil springs - broken?
Use a long strong lever to see if joints will move apart too easily.
Check for play in the dog bone mount
Is your engine moving around too much
With front wheels up, if you can feel play 9 to 3 but not 12 to 6 have a closer check on the track rods
The exhaust has a support hanger just after the downpipe as well.
