2011 1.2TSi Alternator belt question
Scratchman
33
Our 1.2TSi has started making a droning noise from the right side of the engine. based on previous experience it sounds to me like alternator belt or tensioner / idler bearings.
There's not a lot of room in there, is there a "how to" for changing the belt and tensioners?
RUM4MO
7,823
999
South Scotland
Worst case would be to jack it up and remove the RHS front wheel and if needed, the wheel arch liner - that is if you can't be a contortionist and attack it from above?
Is your battery in good health, as a dying battery will keep the alternator working very hard and so noisier than it used to be?
Scratchman
33
Battery is OK as far as I know but I will check it before going crazy buying bits.
