show blower speed on auto
siri_uk
Hi guys
I have a 2017 seat alhambra i'm trying to enable fan speed on auto. I followed :-
Climatronic: Enabling blower fan level display on auto.
08auto hvc
07 Long Coding
Byte 11
Enable Bit 6
I have no byte 11 bit6 in the long coding helper, can anyone help
Deleted member 103408
Don't know the Alhambra but on the Leon its Control unit: 08 Air Conditioning, Just checked the OBD11 boards for your car and they show
Fan Speed on Auto Mod
Select Control unit 08 (Air condition A/C)
Control unit Long Coding
Byte 11
Bit 6 Activate
Hope that helps
siri_uk
Thanks for the reply, on vcds i don't have bury 11 bit 6 to activate
Sent from my SM-G955F using Tapatalk
siri_uk
Do you have any Bytes on Control unit 08
there is nothing in 08, this is the scan from vcds
Address 08: Auto HVAC (J255) Labels:. 5K0-907-044.clb
Part No SW: 7N0 907 044 AT HW: 7N0 907 044 AT
Component: Clima-Sharan H04 0606
Revision: 00001K06
Coding: 021010C549
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_ClimatronciSharan A01005
ROD: N/A
VCID:
Subsystem 1 - Part No SW: 7N0 907 049 C HW: 7N0 907 049 C
Component: KBT-H 004 0103
Serial number: 20170901000000132974
No ASAM data for: "EV_ClimatronciSharan" (VW36 *)
No fault code found.
I get a message in vcds saying unable to find a .ROD file for
EV_CLIMATRONIC|saharan a01005 (vw36*) make sure you are using the latest version including beta. I am using 17.8.0
Sorry I am not a vcds user so cant help on the .ROD or version but in simple terms you cant make any changes because you cant communicate with it. Might be worth a chat on the ross tech forums if nobody can help here.
