hi can anyone advise me please.
had new lamda sensor (proper one ntk). then the map sensor needed replacing. all done it was like new until I hit 300 miles (in 1 weekend) and the epc and engine light came back on. took it back to the garage tested wires etc for the map sensor couldn't find anything wrong. took it for 2nd opinion he said the map sensor was cheap and a bad fit. took back to original garage he said he used a sovereign map sensor nothing wrong with it... Should I get another bosh map sensor and try that or am I throwing my money away?
these are the codes from vcds
Address 01: Engine Labels: 036-906-034-APE.LBL
Controller: 036 906 034 DG
Component: MARELLI 4MV G 5953
Coding: 00071
Shop #: WSC 04941
VCID: 5AC7116BD507
VSSZZZ6LZ8R153103 SEZ5Z0H1191086
1 Fault Found:
17563 - Manifold Pressure Sensor (G71): Short to Plus
P1155 - 35-10 - - - Intermittent
Readiness: 1010 0101
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS.LBL
Controller: 6Q0 907 379 AF
Component: ABS 8.0 front H05 0002
Coding: 0002181
Shop #: WSC 04941
VCID: 817586079811
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory
18265 - Shareware Version. To Decode all DTCs
P1857 - 000 - Please Register/Activate
cheers in advance
dora x
Coding: 00071
Shop #: WSC 04941
VCID: 5AC7116BD507
1 Fault Found:
Coding: 0002181
Shop #: WSC 04941
VCID: 817586079811
2 Faults Found:
cheers in advance
dora x
