Chris Knott
Go Back   SEAT Cupra.net - SEAT Forum » SEAT Model Specific Discussion Forum includes Members Projects » Ibiza » Ibiza Mk4
Ibiza Mk4 For the 2002 - 2008 model
Reply
Thread Tools Rate Thread Display Modes
Old 18-01-2010, 21:37   #1
ibizadoyle
ibizadoyle's Avatar
ibizadoyle has 10 points
camber adjustment
hi does the ibiza fr tdi have adjustable camber?? if not is there any camber adjustment ends available to fit at all?
many thanks simon
__________________
Ibiza FR- Performance Torque Stage 1 Map!- Green Cotten Filter- 15mm Spacers- Seat Sport Strut Brace- Leon MK1 FR Wheels- Turbo Back Custom Exhaust!!- Boost Guage!!- LCR Spliter- V-maxx Coil Overs- Seat Sport FMIC!!!192.5bhp and 295lb of tourque!!! got boost RR 6/12/09
ibizadoyle is offline   Reply With Quote
Old 18-01-2010, 21:45   #2
RUM4MO
Senior Member
RUM4MO has 40 points
There is no camber adjustment intended, but a small ammount can usually be found in bolt holes.
RUM4MO is offline   Reply With Quote
Old 18-01-2010, 22:01   #3
Gooner_Mike
Teaching the kids
Gooner_Mike's Avatar
Gooner_Mike has 20 points
Not as standard but you can buy camber shims...
An example: http://www.wheel-*****s.com/forum/vi...hp?f=17&t=1236
__________________
Gooner_Mike
Ibiza FR 1.8T old RR Thread
Citroen C4 VTR+ HDi current RR Thread
Gooner_Mike is offline   Reply With Quote
Old 18-01-2010, 22:03   #4
RUM4MO
Senior Member
Ah, with coilovers already fitted I thought the problem would be at the front end! Ah your link has been nobbled probably by the polite police!
Old 19-01-2010, 10:01   #5
ibizadoyle
ibizadoyle's Avatar
yea it the front that is causing the problems is it cause i have lowerd my vehicle?
__________________
Old 19-01-2010, 12:02   #6
DEAN0
DEAN0's Avatar
DEAN0 has 20 points
Quote:
I thought camber shims were only any good on the back where the stub axle mounts to the beam using a flat flange ?
Three options for the front that i am aware of are :
CUPRA wishbones are slightly shorter to correct the camber of a lower ride height as standard.
You can slot the three holes in the outside of the wishbone to bring the wheels in and correct the camber.
You may be able to find eccentric or adjustable top mounts to correct camber
DEAN0 is offline   Reply With Quote
Old 20-01-2010, 18:09   #7
basssound
basssound's Avatar
basssound has 10 points
looked into this, only way I could think of this is to make up some new shorter bottom arms, one off's
BUT
unless your a fabricator or got wads of dough, this is gonna be expensive.
I also thought that to alter the camber via the bottom it would make to drive shaft too long as the
pulling in of the bottom of the strut WILL shorten the shaft.
basssound is offline   Reply With Quote
Old 20-01-2010, 18:26   #8
techie
Skoda Techie
techie has 20 points
Altering the position of the lower ball joint also alters your castor angle.
Top mounts is the best way forward, expensive though.
techie is offline   Reply With Quote
Old 20-01-2010, 22:26   #9
DEAN0
DEAN0's Avatar
DEAN0 has 20 points
Quote:
How ? - If all you do is move the ball joint in towards the chassis by slotting the wishbone holes - the castor will remain the same.
I agree that if the ball joint moves forwards or backwards you will change the castor.
The same is true with eccentric top mounts - they change camber and castor at the same time.
Old 20-01-2010, 23:02   #10
ibizadoyle
ibizadoyle's Avatar
where can i find eccentric top mounts? dont like the sound of fabricating bottom arms or anything
__________________
Old 20-01-2010, 23:07   #11
DEAN0
DEAN0's Avatar
DEAN0 has 20 points
Usually a motorsport suppliers.
these guys dont list ibiza or polo but you could ask
http://www.motorsportengineering.co....p%20mounts.htm
KW do them but they are NOT cheap
http://www.venommotorsport.com/manuf...at&model=Ibiza
Old 20-01-2010, 23:12   #12
vroomtshh
vroomtshh's Avatar
vroomtshh has 10 points
Instead of wating money on top mounts, you can adjut the holes in the strut tower.
Mine had the holes slotted, camber adjusted to where it needed, then a washer welded to the strut tower in the correct position
vroomtshh is offline   Reply With Quote
Old 21-01-2010, 19:36   #13
ibizadoyle
ibizadoyle's Avatar
have you gt any pictures? them top mounts look well over priced for what they do!!!
__________________
Old 21-01-2010, 19:45   #14
knackerdecobre
Posts: n/a
Not really as they aren't really designed for people using them on road to set them up once and leave it. If you are doing lots of track days or entering a race series they are very good
Old 21-01-2010, 19:55   #15
vroomtshh
vroomtshh's Avatar
Quote:
Can you explain why people doing lots of track days or a race series would need to adjust camber more often than someone in a road car?
Old 21-01-2010, 21:41   #16
knackerdecobre
Posts: n/a
As you change the suspension geometry to suit the track/conditions. for example a high speed flowing track would require different camber settings to a tight twisty one
Old 21-01-2010, 22:43   #17
ibizadoyle
ibizadoyle's Avatar
can you buy camber shims to correct it then?
__________________
Old 21-01-2010, 22:52   #18
RUM4MO
Senior Member
Yes you can - FOR THE REAR END! We have worked out that its the front end that you are trying to sort out.
Old 22-01-2010, 00:09   #19
knackerdecobre
Posts: n/a
IIRC, using Cupra wishbone bushed helps too (as a cheap fix)
Old 22-01-2010, 01:30   #20
dervpower
Senior Member
dervpower's Avatar
dervpower has 10 points
Having just the same issues mate. Tyres have just lasted me 5500 and now need changing! Right piss take!
Think Laser allignment and cupra bushes will help, although fitting on the bushes can be around £150/£200... Cheaper to buy tyres lol
__________________
Will
dervpower is offline   Reply With Quote
Reply
Bookmarks
« Previous Thread | Next Thread »
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
(View-All Members who have read this thread : 159
1.2honest, 5509433, aanev, AdamSmith, Aimez, ajanja, alexbailey12, Altech, andypandypoos, ant49, Arkaig, Arnoldo, Art0ir, atsimas, bald_eagle, basssound, Belbing, binkylad, Bobsey, broadbandings, byerss, Chocozai, chris4500uk, Chris@apt, CJFR, CJRamze, Connarbrown, corndog, crespo1987, CrossyR, cupra.al, cupra14, Cupra20v, cuprajose, cuprar51, D4V2K1, Danhead, dann2707, Dannym, davidcaffery, davidif, daytona246, DEAN0, deanogee7, dervpower, dErZ, dicky FR, dionbee93, dm222, Dorny, DScape, ecklad, Edward9th, Elliman98, EZ Tutty, Ferryman, Fien, Fl@pper, Flash20vt, FRobot, gac, garethgje, george130, gex18, Glenntmckee, glenpring, Gooner_Mike, Hartosh1, hazzagrant, Headsnap, ibiza64, ibizadoyle, ibiza_1.4tdi, irf, J41R0, J5HDK, jacko_86, JamesT, jeffery, jenyz, Joe's MK4, Johnson, jonny_mcc, joop200789, Jordanwaterhous, JR_130, jumbo77, Just Waxed, kacer, keithr, kidinspace, killbot, Kingscote, kobchai, L8W FR, laawtytdi, lankman, Leespat69, leon cupra r, Leonsteve, lmow01, luna fr, m.r.davies, mark20vt, Marshall, MasserS, MATT RILEY, mattmk2, Matty589, Mattyboy1, mc funbot, mcsolle, Mick288, Mickylad, MPJ88, MrNorma, nam, Neo, nicko16, NickP29, NickyJam, ninjabadger, nvidia, Phil_JJ, pjdj, processpaul, PSX, psycho6285, Ric 2001, richard booth, Risto, RMJ, ROBD--M15RPD, RSAlex, RUM4MO, Scott-o, Shroom, singh123, sonnex22, splitpin, stu 157-330, stupot_1982, syko, Syko2005, tarzan, tdi_swedge, techie, telwick, tequilan, tomH, uzi_cupra, Vrchris, vroomtshh, weerobocupra, wezy0, wilz, wolfie150, zach225
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Camber adjustment mpgscott Leon Mk1 3 13-11-2009 09:06
camber adjustment ???? smithcupra Ibiza Mk2 8 08-11-2009 12:04
Camber adjustment on LCR's??? leon7284 Leon Mk1 34 20-07-2009 12:30
Front camber adjustment..how to ? and wheel wobble question r8byb Ibiza Mk3 16 20-01-2008 19:10
Website © 2014 SEATCupra.net
Disclaimer: SEATCupra.net is not an official SEAT site and is not affiliated to SEAT in any way. Visit the Official SEAT Website.
SEATCupra.net are not directly responsible for information which maybe posted in this forum.
All content is viewed and used at your own risk. We do not warrant the accuracy or reliability of any of the information.
The views expressed herein are those of the individual contributors and not necessarily those of SEATCupra.net or SEAT
All trademarks and copyrights remain property of their respective owners.
