Let the oil out first
Take the return pipe from the turbo off completely. Stuff some clean paper towel in each end of the pipe and the open hole in the turbo - you don't want any dirt getting in.
Disconnect the level/temp sender if you have one mounted in the bottom of the sump.
There are 20 bolts holding the sump to the crankcase and three horizontal ones holding the gearbox to the sump. Remove the gearbox ones, and loosen the crankcase ones diagonally (1, 10, 5, 15, etc). Don't lose the bolts - those magnetic trays are good.
Light tap with a soft mallet may be needed to crack the seal - careful, the sump is aluminium.
Clean both mating surfaces. They must be completely free of the old sealant. The sump only seals against the crankcase - the gearbox connection is for rigidity.
Apply a continuous 2-3mm bead of sealant around the sump, running it from one hole to the next then make a half-moon inside the boltholes. At the gearbox end, don't stray too far from the inside edge of the sump. I think it's worth getting the proper VAG sealant.
Bolt up the sump diagonally to the crankcase to 5Nm.
Fit the gearbox bolts and tighten to 45Nm
Finish tightening the sump - diagonally - to 15Nm
Fit turbo oil return pipe. Don't forget to take the paper out. Reconnect the level/temp sensor.
Wait at least 30 minutes for the sealant to harden before filling the sump with oil.
If you've overdone the sealant it squeezes out into the sump, hardens, drops off and blocks the oil pickup mesh strainer.
