2009 Altea XL 1.6 BSE EPC light on and misfire detected
ialtea
Hi there,
I have been experiencing some issues for the last two weeks. EPC light is on and occasionally now power in low revs when accelerating. VCDS checks show following codes:
Any help will be greatly appreciated! :)
Chassis Type: 5P-SE35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72
VIN: VSSZZZ5PZ9R504231 Mileage: 211990km-131724miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 HE
Component: SIMOS71 1.6l 2VG 1037
Revision: --H04--- Serial number:
Coding: 0004071
Shop #: WSC 06402 785 00200
VCID: 69FD824C66863FFB98-803C
VINID: 9A38EAAAA160A8988500408304C34B2522
3 Faults Found:
16685 - Cylinder 1
P0301 - 006 - Misfire Detected - Intermittent
Freeze Frame:
RPM: 2624 /min
Mass Air / Rev.: 294.3 mg/str
Temperature: 46.5°C
Lambda: 0.0 %
RPM: 1920 /min
Mass Air / Rev.: 201.7 mg/str
Temperature: 54.0°C
Lambda: 0.0 %
16688 - Cylinder 4
P0304 - 006 - Misfire Detected - Intermittent
Freeze Frame:
RPM: 2624 /min
Temperature: 46.5°C
Lambda: 0.0 %
RPM: 1920 /min
Temperature: 54.0°C
Lambda: 0.0 %
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 006 - - Intermittent
Freeze Frame:
RPM: 2624 /min
(no units): 255.0
(no units): 0.0
RPM: 1920 /min
(no units): 0.0
(no units): 0.0
Readiness: 0000 1000
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 213F2012092200FE840D04E7901A00403400
Shop #: WSC 33920 001 104857
VCID: 760E9875FAF9614600-8022
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 3
Reset counter: 151
Mileage: 211989 km
Time Indication: 0
Date: 2017.05.09
Time: 17:16:42
Freeze Frame:
Count: 64
Count: 0
Count: 4608
Count: 8196
Count: 52256
Count: 254
Count: 0
Count: 0
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 HW: 1K0 937 086
Component: BCM PQ35 M 020 0361
Revision: 00020000
Coding: 40180A1C902508E04280008595008104075100A8427DC9601E8040000000
Shop #: WSC 80092 264 94871
VCID: 6DF98A58D6AA1707B8-8038
Subsystem 1 - Part No: 5P0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 25030 22 0601
Coding: 00DB90
Subsystem 2 - Part No SW: 1P0 955 559 A HW: 1P0 955 559 A Labels: 1P0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 02542E
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 211980 km
Time Indication: 0
Date: 2017.05.09
Time: 20:22:05
Freeze Frame:
Term 15 Off
Voltage: 11.95 V
OFF
ON
Term 50 Off
OFF
OFF
ialtea
Found the problem. One of the spark plugs was loose. It's probably caused the fuel mixture issue and misfire.
