A boat load of error codes
Compo1
272
64
Hi all
Well i had the engine light come on this morning so ran a Full Scan on VCDS
It came up with the codes below and on checking a 10 amp fuse was blown .
Replaced thr fuse and it blew within a mile of driving after clearing the codes which also returned,
As all the code relate to that fuse which is fuse 7 i think, i suspect ive a break in the wiring harness somewhere.
Anyone ever had this or similar array of codes ?
Any areas to look at maybe that are common areas for the harness to chaff ?
13871 - Coolant Pump for Intercooler
P023B 00 [039] - Short to GND
17971 - Heater Support Pump
P16BF 00 [039] - Short to GND
10385 - Coolant Valve for Cylinder Head
P199D 00 [167] - Short to GND
9490 - Oil Pressure Regulator
P165F 00 [039} - Short to GND
10385 Thermostat for Cylinder Head
P199D 00 - Sort To GND
Compo1
272
64
Fixed the above issue, traced it to the wiring to the intercooler pump right below the oil filter.
This is the one you have to disconnect to get to the oil filter housing properly.
Reactions: mjj4 and DEAN0
