It came with 6 shades - one for each rear door window, one for each C post window and two that when put together form the rear shade. As for "only taking a few minutes to install" I suppose that depends on whether you stick the adhesive clips onto the inside of the window frame of the rear doors, without using these clips it took me less than 5 minutes to unpack and fit the shades. I haven't bothered with these clips as I'm happy having the shade fit between the window glass and the rubber seal, although I guess if I drove along with the windows wound all the way down I'd risk the shades being sucked out and losing them - however I hardly ever drive with the windows down, and if I do it's only with them wound down by about 2 or 3 cm, in which case I'm pretty confident that the shades are going to stay in place. If you wanted to use the clips provided, I'd estimate it would add about 30 - 40 minutes to the installation time as you are advised to let the adhesive on clips cure for that amount of time before you fit the shades.
