Abs pump constantly running
Nov 4, 2020
I have 2009 1.9 TDI bxe the abs pump is running constantly, even when the keys are out of ignition. I don't know if abs pump is coded I changed my engine from 1.9 bxe 105 to a 2.0 bkd 140. Any chance anyone come across this problem
300bhpdaily
1,246
568
So many things running through my mind.
when you say the abs is running can you explain this further in more detail?
Also you don’t know if the abs pump is coded but you’ve managed to engine swap your car.
is the car running now?
Nov 4, 2020
The car runs yeah starts and drives no faults just the abs, we have changed all wiring harness, and everything electrical apart from power steering pump, I had a donor car. Were the engine came from. I'm thinking that it might be a bad abs pump if I get a new one would I need to code the abs?
