advise please
mty12345
3,771
476
bristol
Hi there, welcome to the forum. If i was you i would repost this question in the leon mk1 thread, a lot more people will see it there. http://www.seatcupra.net/forums/forumdisplay.php?f=21 Scroll down to the bottom of the list to start a new thread there.
When you say it moves, by how much? If you can be more specific when you repost it in the mk1 section then i'm sure we can help :)
LillianJacks
15
carseatresearch.com
The only thing you should really need to worry about is starting the motor without lubrication.
The rest of the servicing work can wait until after it's running.
To be careful: pull the ignition primary wire and crank the motor a couple times so the oil pump can fix that.
To be really anal: pull the plugs and lube the cylinders then use a big socket to crank by hand a few times.
