Altea xl 2010 tdi se
Mar 5, 2024
7
Hi all , possibly someone has come across this problem before now .
2010 Altea xl Tdi SE 2.0 , bulb failure light on in display , multiple exterior lights not working , ran vcds , shows rear fog bulb fault , front fog bulb fault , plus the following : 00927-Terminal 30 (Right) . 011 open circuit- Intermittent
I understand Terminal 30 is a battery positive feed , but where or what is it feeding ?
Have tested all bulbs apart from number plate , which I shall do shortly. Indicators , side/stop all affected , Is there a module somewhere or fuse somewhere other or is it possibly an earth fault ?
Have had this car for 13 years with no problems 89K on clock
Larry
