Why am I only getting 70g/s max? Tried original airbox, which is still the same.
No fault codes? 10psi max maybe hits 11psi in 4th.
Do I need full vagcom to log 115 and 118?
Checked vac pipes and boost pipes, all seem good, going to make a leak tester and see if I can find any leaks, which pipe do you clamp to stop pressurising the crankcase?
