Central Locking!!
bruza
Hi everyone!
Basically my central locking stopped working a few days ago :( The LED light on the fob still flashes so im assuming the battery is still working. I've been through some threads already about re-programming but it hasnt worked [:@].
Any ideas??
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
do the doors lock ok manually firstly ?
then either test/change the batteries anyway as the light (led) will light even with next to no voltage at all in there
bruza
Yeah it locks manually.. ok cheers mate will have to try that out!
Any other suggestions?
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
just some hope and mojo from it being 99% of the time batteries / coding / remote only
if that helps :) :)
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
oooh forgot to add
if you can measure em, make sure batteries are over 2.95v each as they are usually pretty useless under that
bruza
Just got the batteries replaced with 2x 3v's. Still no luck :(
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
bugger - got a mate with similar car ? as the remotes are 'brain dead' until you code them to a car so you can code them back 'n' forth all day long
how are you recoding it ? worth trying a few times or swap buttons over too
Key coding
1 ignition on to red lights on dash
2 turn off immediately and pull key out
3 hold 1 of the buttons down (dont matter which)
4 PRESS the other 3 times ( with a SLIGHT pause) 1 . 2 . 3
5 watch led on key (should flash) and doors usually try lock/unlock
6 turn ignition key back on to red lights and wait 5 sec
7 key out again and test operation
bruza
Dont know anyone with an Ibiza :(
Tried re-coding again and didnt workk[:@]
Any other possible solutions? :)
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
new remote ?
used to try em on site when asked for one as they used to be ready to go but i doubt dealers nowadays do such a thing sadly
allyboy
62
i had the same problem the dealer said they had to disconnect the cental locking pump and reconnect it and when that was done they coded in no problem
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
mk2's had the pump in the OSR 1/4 panel as they were air operated
mk3's are electronic so the control unit under the dash runs motors on each door/flap/gate
aterro
Banana Bomber
Oct 28, 2009
118
i am also having the same problem as you bruza
pressing the buttons and it flashing
but no respones from the car
mk3
what does the control unit actually look like so i know what im looking for? and whhere is it located?
thanks
