Dash Cam Installation
Villabrand
91
33
Has anyone fitted one of these just by running wire in edge of trim, plugged into the 12v in the arm rest?
Considering getting a nextbase but not wanting to take the car apart to hardwire.
Yes, I have a Garmin minicam 2 wired to the 12v socket. Can be done fairly easily. Run down windscreen side of A pillar so barely visible. Then under door sill trim.
Hardest part is getting cable under passenger seat rails to the centre console.
the_lorne_ranger
62
18
Aberdeen, Scotland
Cheers!
Looking at getting one today, but having wires all over the place put me off.
Will look at hardwiring at a later date, but from vid on here looks pretty easy!
radiocaf
12
Definitely can vouch for the airbag switch throwing up an airbag error. I had to buy an OBDeleven to clear it because a normal OBD scanner can't even see the fault, let alone read it.
Reactions: Wyld Stallyn
