Went for the MOT and predictably it failed!! - But on something unexpected!
"Offside front (
lower arm bush) Bonded suspension unit bonding failed and part of unit is likey to become displaced"
Which basically means this:
Fortunately I had already purchased two NEW genuine wishbones in anticipation of a suspension upgrade I've been planning.
I replaced the original rear bushes with NEW genuine Leon
Cupra R solid items as a slightly firmer upgrade.
These were also fitted with NEW OEM ball joints and coated in 2 coats of Eastwoods extreme chassis paint (satin black). This gives a very OE finish though in the pics here its hidden under a smear of waxoyl.
With the car back home and up on axle stands the relatively straightforward task of swopping the wishbones turned into a nightmare as one of the original wishbone pivot bolts rounded and the other was near to doing the same.
It was clear the only way forward was to remove the subframe and give it to someone else with better tools to remove the pivot bolt. So using the Haynes manual as my bible off came the subframe complete with both wishbones (-1 ball joint), the ARB/droplinks and engine mounts.
This was what was revealed - I decided then there was no way this would be refitted in this condition! On the second pic below you can see the bush separating from the wishbone.
The local garage removed the pivot bolts and I stripped the the subframe down - the photos are blurred as I was shaking due to it being freezing cold!:
