Guys don't forget to do the DIELECTRIC GREASE treatment on your MAF[Mas Airflow Sensor] on your new Mk11 Leon.Just done mine this morning and I swear it is even smoother than before,or is it my imagination.
You need to remove the cover cap on the sensor by unclipping from the side then remove the plug by depressing the side clip and give it a tug.For anyone that doesn't know the sensor is located on the top of the airbox on the pipe to engine air intake,NOT COLD AIR FEED PIPE. Daub the connectors with DIELECTRIC GREASE that you can buy off ebay if you want,then plug and unplug a few times,then reapply some more grease and refit plug and don't forget to replace the plug cover cap.I did not have to totally remove the cover cap,just moved it enough to get at the plug clip.BINGO.Car runs really smoothly.
Even if you don't think it makes a difference at worst it is a preventative measure for the future although I reckon it has done the business on mine even though cars only covered 7.5k.
