... but not Christmast time.
Have Ibiza 2011, diesel 77 kW.
From few days ago, car started normaly, but many lights stay (go) on:
- engine
- brake
- steering
- glow plug (blinking)
ABS and servo steering NOT work.
Check fuses in main box - all ok.
Also check 3 fuses in small box near battery, also OK.
Check both connectors on ECU and one on ABS unit - also ok.
Want to check relays - but not find - only two is near (upper) fuse box and one near battery.
Where is?
Have this car more (hidden) fuses?
Have this car special or main CAN-BUS relay unit?
Any idea, solutions?
Make diagnose with VCDS, here is full log.
Try to erase DTC, but on ECU stay, also can not erase in some units.
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Cannot be reached 1100
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
4B-Multifunc. Module -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels: None
Part No SW: 03L 906 023 LD HW: 03L 906 023 Q
Component: 1,6l R4 CR td H33 8836
Revision: --H33--- Serial number:
Coding: 00114016002400080000
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_ECM16TDI02103L906023LD 003005
ROD: EV_ECM16TDI02103L906023LD.rod
VCID: 73E1DBFF6975
1 Fault Found:
6086 - No Communication with ABS Brake Control Module
U0121 00 [173] - Short to Plus
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 65
Mileage: 184642 km
Date: 2053.14.28
Time: 16:41:15
Readiness: 0110 0000
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 6J0 820 043 C HW: 6J0 820 043 C
Component: Climatronic H07 0606
Revision: S0000000
VCID: 2443E8A39C1B
2 Faults Found:
01316 - ABS Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 184041 km
Time Indication: 0
Date: 2120.14.18
Time: 17:09:51
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 8
Reset counter: 1
Mileage: 184041 km
Time Indication: 0
Date: 2120.14.18
Time: 17:09:55
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0251
Revision: BF046001 Serial number: 0434 157111298
Coding: 228829E888610100002000006E0B0CC80080400F608C0000200000000000
Shop #: WSC 64564 324 38760
VCID: 458555277761
Subsystem 1 - Part No SW: 6R0 959 801 N HW: 6R0 959 801 N
Component: J386__TSG_FT 003 3130
Coding: 020000
Subsystem 2 - Part No SW: 6R0 959 802 Q HW: 6R0 959 802 Q
Component: J387__TSG_BT 003 3130
Coding: 020000
2 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 1
Reset counter: 41
Time Indication: 0
00538 - Reference Voltage
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 3
Reset counter: 41
Mileage: 184041 km
Time Indication: 0
Date: 2120.14.18
Time: 17:02:08
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10AirbagA01 H09 0020
Revision: -------- Serial number: 003GX00NVXJT
Coding: 003031
Shop #: WSC 06401 785 00200
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 4A9F661B5E7F
Driver's Airbag Crash Sensor:
Serial number: 3495RRB405P0K4DOC92W
Passenger Side Airbag Crash Sensor:
Serial number: 3505RRB40530KSEGEGRA
2 Faults Found:
12854016 - Implausible Data Received from Instrument Panel Control Module
U0423 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 1
Mileage: 184041 km
Date: 2056.14.18
Time: 13:44:55
12656896 - No Communication with ABS Brake Control Module
U0121 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 184041 km
Date: 2056.14.18
Time: 13:44:57
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6J0 920 803 H HW: 6J0 920 803 H
Component: KOMBI H02 0504
Serial number: 00000000000000
Coding: 110A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 2E570A8BC2D7
1 Fault Found:
12656896 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 184041 km
Date: 2056.14.18
Time: 17:10:32
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0251
Revision: BF046001
Coding: 422000
VCID: F0EB54F39863
2 Faults Found:
00470 - Combination comfort Databus in Single Wire
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 41
Mileage: 0 km
Time Indication: 0
Date: 2120.14.18
Time: 17:49:31
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 184041 km
Time Indication: 0
Date: 2120.14.18
Time: 17:11:28
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H02 0504
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: EADF469BBEBF
No fault code found.
Address 2E: Media Player 3 (J650) Labels: None
Part No SW: 6J0 035 342 E HW: 6J0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660192814
Coding: 020000
VCID: 2647F2ABEA27
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 10121
Shop #: WSC 06402
VCID: 2F69178FC5DD
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
79-00 - Please Check Fault Codes
Address 4B: Multifunc. Module Labels: None
Part No: 6J0 959 441 A
Component: MF-Modul 0007 0001
Coding: 0000002
Shop #: WSC 77005 000 00000
VCID: 316D11F7D3E9
1 Fault Found:
011 - Open Circuit
Address 56: Radio (J503) Labels: None
Part No SW: 6J1 035 153 H HW: 6J1 035 153 H
Component: Radio H15 0302
Revision: R0000000 Serial number: SEZAZ2M4066140
Coding: 0001040002
Shop #: WSC 48314 001 1048576
VCID: 2A5F069BFE3F
Address 69: Trailer
Cannot be reached
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2730
Revision: 1B001001 Serial number: 00007660187645
Coding: 0800000001010110
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_UHVNA A01015
ROD: EV_UHVNA_SE25.rod
VCID: 356525E72781
End ---------------------------------------------------------------------
- engine
- brake
- steering
Where is?
VCID: 73E1DBFF6975
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 65
Mileage: 184642 km
Date: 2053.14.28
Time: 16:41:15
Cannot be reached
Revision: S0000000
VCID: 2443E8A39C1B
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 184041 km
Time Indication: 0
Date: 2120.14.18
Time: 17:09:51
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 1
Mileage: 184041 km
Time Indication: 0
Date: 2120.14.18
Time: 17:09:55
VCID: 458555277761
Coding: 020000
Coding: 020000
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 41
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 41
Mileage: 184041 km
Time Indication: 0
Date: 2120.14.18
Time: 17:02:08
Coding: 003031
VCID: 4A9F661B5E7F
2 Faults Found:
U0423 00 [009] - -
Freeze Frame:
Fault Priority: 6
Reset counter: 1
Mileage: 184041 km
Date: 2056.14.18
Time: 13:44:55
U0121 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 184041 km
Date: 2056.14.18
Time: 13:44:57
Coding: 110A00
VCID: 2E570A8BC2D7
1 Fault Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 184041 km
Date: 2056.14.18
Time: 17:10:32
Revision: BF046001
Coding: 422000
VCID: F0EB54F39863
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 41
Mileage: 0 km
Time Indication: 0
Date: 2120.14.18
Time: 17:49:31
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 184041 km
Time Indication: 0
Date: 2120.14.18
Time: 17:11:28
Serial number:
Coding: 000000
VCID: EADF469BBEBF
Coding: 020000
VCID: 2647F2ABEA27
Coding: 10121
Shop #: WSC 06402
VCID: 2F69178FC5DD
1 Fault Found:
Coding: 0000002
VCID: 316D11F7D3E9
1 Fault Found:
011 - Open Circuit
Coding: 0001040002
VCID: 2A5F069BFE3F
Address 69: Trailer
Cannot be reached
VCID: 356525E72781
