Hi,
I usually do a winter/summer wheel swap on the drive, using the factory jack for both of our cars with no issues. Having done this 2 years running on a Mk2 leon and Golf Mk6 using the factory jack on the pinch weld lip, the jack for both of these cars was the same and had a recess for the lip to sit in, but ultimately seemed to actually lift the vehicle at the base of the pinch weld where it meets the chassis.
I did the exact same with our new Leon Mk3 earlier this year, however due to not having a spare wheel I purchased the correct jack from Seat spares. I noticed they had changed the design, feels more robust but the contact point has changed. Now the jack has a flat metal plate which the pinch weld sits on. Therefore all of the cars weight is now passing through the edge of the pinch weld, afterwards i noticed the rubberised coating and paint had annoyingly split. I put a layer of touch up stick on, so hopefully this wont rust
I am yet to get my facelift Ibiza Cupra, which i understand comes with a spare wheel, and should have a jack in it.
My question is; Does anyone have a picture of the Ibiza Facelift jack that comes in the boot - I wonder if they changed this design too?
I was planning on putting a piece of rubber on the Leon Jack's edge to soften the contact point (to make kind of a jack pad) and wondered what you all thought? Considering i only ever jack our cars up for wheel swaps, I have never purchased a trolley jack - plus i'm not that confident with where i should use it on the underside of the car: some people say you can use them on the usual jack points, others say its bad for the car. I am cautious of buying something cheap and it failing on me - least with a scissor jack the seals cant suddenly fail!
What are your thoughts on this, I guess most of you own a trolley jack, if so are there any reliable ones that arent mega bucks? I won't be putting axle stands underneath for a wheel swap
Also, do you think VAG changed the jack design purposefully so that the jack only touches the edge of the pinch weld instead of the underside of the chassis?
Sorry for all the questions,
Thanks in advance,
Ben
Thanks in advance,
Ben
