I used them a few months back to put new brake pads on my rear brakes. Done without any hassle and quickly too. Dropped it off in the morning and went to a local cafe for about an hour.
Yep I have upgraded my fronts (Tarox) and have had that for about 8 months now. Got a set of R32 Rears ready to go on but I am going to send them away to get powdercoated the same colour as the Tarox's.
Alex
Sounds sweet Alex, will look forward to the pics when the rears are installed. I guess the fronts look the part and will stop a bus, ala Owen's RS4 setup? nice!
Another general question (im untrained...!) please,
Do i require all of the kit listed below for conversion of MKII FR TDI to MKII
Cupra? What im trying to say is there any common parts that can be re-used or is it not really worth it for the cost of the new parts anyway?
Upgrade FR brakes to
Cupra - MKII Leon
LEON Mk2 345mm BRAKES AS FITTED TO
CUPRA
LH CALIPER 1K0615123K £67.70
RH CALIPER 1K0615124K £67.70
CARRIER 1K0615125G qty 2 £90.46 ea
RETAINING SPRING 4F0615269 qty 2 £8.52 ea
PAD SET 1K0698151B £41.19
BRAKE DISC (345x30mm) 1K0615301M qty 2 £55.94 ea
LH SHIELD 1K0615311C £5.60
RH SHIELD 1K0615312C £5.60
FLEXI HOSE 1K0611701N qty 2 £9.64 ea
BOLT N10647602 qty 4 28p ea
SCREW N90948802 qty 4 £1.15 ea
SCREW N91073301 qty 6 10p ea
BRACKET 1K0611841A 80p
BRACKET 1K0611842A 80p
SCREW N90718601 qty 2 25p ea
PIPE 1K0611763A £4.35
PIPE 1K0611764A £4.35
CLIP 191611715 qty 2 42p ea
THIS LIST IS BASED ON WHAT WE SUPPLIED A FORUM MEMBER TO UPGRADE HIS LEON AND EVERYTHING WAS 100% HOWEVER THERE IS A QUERY WHETHER SOME MODELS MAY NEED NEW HUBS AND CARRIERS - ANY ADVICE WOULD BE GREATLY APPRECIATED
THE 286mm REARS AS WELL
LH CALIPER 1K0615423P
RH CALIPER 1K0615424P
CARRIER 1K0615425J qty 2
PAD SET 1K0698451D
BRAKE DISC (286x12mm) 1K0615601M qty 2
LH SHIELD 1K0615611P
RH SHIELD 1K0615612P
LH FLEXI HOSE 1K0611763E
RH FLEXI HOSE 1K0611764L
the above was copied from an old Dave Sere NI post. I never saw any conf to all of the above being required / or not? Any info on what I may be missing / do not require from above to change my setup would be much appreciated,
Ive tried searching but cannot find the idiots
guide i require!
Cheers again,
D
