luig
Help.
The interior light has stopped coming on, but only when the drivers door is opened. It works fine when the passenger door is opened.
The lights left on alarm has also stopped working but thought this was also part of the problem.
I am thinking some sort of door switch problem, but don't know where this is/ where to find it.
I have looked all over door, but can't find switch, nothing on hinge side and nothing on lock side.
The interior light comes on as usual when you take the key out of the ignition but not when the door is opened, and the buzzer does not work under any situation.
Also the red door open warning light does not come on with the drivers door open.
If i know where the buzzer is i can check and rule that out, and maybe trace wires back to door switch?
Anyone know, or had similar problem and know fix?
