help needed guys
Dec 8, 2022
hi guys hope your all ready for xmas ok i have i seat leon mk2 1.9 tdi with to major faults firstley front wipers have stoped working fault codes 00153 driver wiper motor and code 02071 local data bus ive tried a new motor still no joy checked for voltage at the plug 10v on the thick wire and the thin wire 6 to 8 volts can anyone help also where is the starter motor relay located many thanks every
mty12345
3,771
476
bristol
Here is the ross tech fault codes for that fault. http://wiki.ross-tech.com/wiki/index.php/00153
Seems it could be the bonnet switch. I guess wipers are disabled if its open.
As for the starter relay, i'm not famililar with the Mk2, but in the Mk1 there is no relay, it goes straight from the ignition switch to the small terminal on the starter motor.
