Help please
Feb 27, 2024
Hi I’ve just purchased a 2015 Leon FR and I feel like the circled bottom corner should be showing me the speed but it’s always blank with just the 3 dashes showing, any ideas?
Also the left wing mirror seems to be very temperamental and I’m unable to set the position for the tilt when in reverse. Any help welcomed as I’m still trying to get to grips with car after my last one which the most modern thing on it was electric windows!
Feb 27, 2024
That's your cruise control indicator - lights up when cruise is set.
To set your dipping mirror the mirror control knob on the door panel must be set to the left mirror position, have a search in the forum as there have been detailed setting instructions posted before.
Ahhh ok now to find out if I have cruise control and how to set it!
i have used the instructions I found on here previously but sometimes I can’t even adjust the left mirror normally while driving it’s just playing up I’ll try again later though.
thank you for your help
Sep 22, 2023
If that logo is on your screen, you can bet you have cruise control. Check for a cruise control lever just under your indicator lever on your steering housing.
