High CF's, new logs with FMIC fitted
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Hello All,
I need help, I have a MY05 LCR, with the mods listed in my sig below, anytime I do logging I always see lots of CF’s, I have read a bit about them and basically they are correction factors and caused by the ECU retarded the timing for a few different reasons? that’s great, but I do not have the knowledge to analysis the logs to see whats what?
The car was remapped in another country on 98ron, we only have 95ron in Ireland, could this be the problem? I have been onto the company that remapped it and they told me not to worry about CF;s that if they get to high the car would go into limp mode to protect itself, I do not know how true this is, but I do know to many are bad.
I did some logging today as below, as while there are CF;s I have seen them much worse, never the less they are still there.In addition to this I see a boost spike to 1.6/1.7 bar and then it drops back to 1.4/1.5 bar, is this too much?
Would any of you kind experts care to take a look over the logs an see if everything is ok? I have considered retarding the timing with Unisettings but would like all yours opinions first.
Thanks in advance, and sorry for all the questions
Worried LCR owner.
P.S I have an FMIC on the way, could this help me reduce CF’s?
Code:
1		1ML906032A  		1.8l R4/5VT      01 0002
05/03/2004	22:15
	Group A:	'003				Group B:	'020
		RPM	Mass Flow	Load	Ign. Timing		Degrees	Degrees	Degrees	Degrees
	TSTAMP	RPM	g/s	%	°	TSTAMP	CF	CF	CF	CF
	0	760	3.19	1.6	6.8 B	0.71	0	0	0	0
	1.41	760	3.28	2	7.5 B	2.11	0	0	0	0
	2.71	800	3.31	2	3.0 B	3.31	0	0	0	0
	4.03	1160	11.33	7.8	22.5 B	4.73	0	0	0	0
	5.45	1360	21.78	16.9	17.3 B	6.14	0	0	0	0
	6.85	2520	17.89	11	8.3 B	7.54	0	0	0	0
	8.25	1520	30.75	47.5	13.5 B	8.94	0	0	0	0
	9.67	1600	30.06	72.9	10.5 B	10.35	0	0	0	0
	10.96	2000	44.89	90.6	12.0 B	11.57	0	0	0	0
	12.26	2560	84.61	100	4.5 B	12.89	0	3	0	0
	13.48	3320	117.47	100	2.3 B	14.08	0	2.3	0	0
	14.69	4120	158.11	100	9.8 B	15.3	0	4.5	3	3
	15.9	4880	183.22	100	9.0 B	16.52	3	7.5	6	6
	17.22	5560	197.31	100	6.0 B	17.79	2.3	7.5	6	5.3
	18.43	6120	204.19	100	11.3 B	19.03	2.3	6.8	5.3	5.3
	19.73	5680	5.03	7.5	6.0 B	20.33	0	0	0	0
	21.01	3800	9.22	6.3	3.0 B	21.64	0	0	0	0
05/03/2004	22:20
	Group A:	'115				Group B:	'031
		RPM	Load	Pressure	Pressure		Lambda Factor	Lambda Factor
	TSTAMP	RPM	%	mbar	mbar	TSTAMP	-	-	bit	bit
	37.65	1920	91.7	1830	1180	38.33	0.984	1
	38.95	2880	117.3	1050	1610	39.56	1	1
	40.24	2080	78.9	1790	1080	40.87	0.945	0.945
	41.48	2480	130.8	2300	1580	42.17	0.899	0.899
	42.78	3320	191.7	2370	2450	43.48	0.883	0.883
	44.19	4080	191.7	2440	2460	44.87	0.836	0.852
	45.59	4920	191.7	2420	2390	46.28	0.821	0.836
	46.89	5560	190.2	2350	2230	47.51	0.836	0.836
	48.22	6080	184.2	2220	2170	48.91	0.828	0.836
	49.52	6360	117.3	1010	2410	50.21	0.828	0.906
	50.83	4680	15	1010	1080	51.52	1.991	1.047
	52.12	2720	13.5	1010	1040	52.8	1.991	1.047
05/03/2004	22:25
	Group A:	'118				Group B:	'032
		RPM	Temperature	Load	Pressure		Lambda	Lambda
	TSTAMP	RPM	°C	%	mbar	TSTAMP	%	%	bit	bit
	0	760	27	0	1010	0.7	0.6	-8.6
	1.39	760	27	0	1010	2	0.6	-8.6
	2.62	1440	27	14.9	1030	3.3	0.6	-8.6
	3.93	1920	25	21.6	1140	4.54	0.6	-8.6
	5.15	3480	24	0	1330	5.72	0.6	-8.6
	6.35	2920	23	0	1070	7.04	0.6	-8.6
	7.64	1840	24	95.3	1150	8.25	0.6	-8.6
	8.87	2240	23	95.3	1460	9.46	0.6	-8.6
	10.16	2880	22	85.5	2360	10.76	0.6	-8.6
	11.39	3680	21	83.5	2490	12.06	0.6	-8.6
	12.68	4560	23	88.6	2390	13.28	0.6	-8.6
	13.99	5280	24	95.3	2290	14.58	0.6	-8.6
	15.22	5840	27	91.8	2140	15.91	0.6	-8.6
	16.51	6360	31	93.3	2140	17.12	0.6	-8.6
	17.72	5120	30	0	1130	18.32	0.6	-8.6
	19.02	3280	30	0	1050	19.74	0.6	-8.6
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Hmm, the thing is though, that octance booster is £10 to £15 over here, so every tank of petrol would cost me a lot more, having said that i will defo give it a go and failing that, maybe adjust the timing to suit the shite petrol we get over here?
thanks for your input James, i just read your thread about poor CF's start to finish, did you get it sorted in the end?
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
If the car was mapped for 98Ron fuel then 95Ron would prob cause some cf's, yes.
You could take out some timing with Lemmiwnks and see if that helps.
Damoegan
Oct 15, 2007
8,993
Newcastle
Potentialy. But if the ECU is pulling back that much as it is it could already be redusing output. If it is and by lowering the timing it reduces cf's then it could potentialy be making more power as its running better.
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
still on it mate, looking at reducing inlet temps, and going to try millers octane plus per tanks then relog.
boost leak testing under way next week aswell, not sure this would cause cfs but im positive theres a leak somewhere.
i adjusted timing both ways, and upped fuelling via unisettings, didnt do anything for my cfs.
:think:
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Hello all,
Well i fitted a new FMIC and my CF's look better, see logs below, temps seem to be down also, they now get lowerthe more RPM i have! does anything else look to have improved from the logs below.
Also i notice the Lambda % values are alot lower, what does this do and should it be lower?
Code:
Group A:	'002				Group B:	'114
	RPM	Load	Inj On Time	Mass Flow		Load	Load	Load	Load
TSTAMP	RPM	%	ms	g/s	TSTAMP	%	%	%	%
0	760	24.1	2.38	3.72	0.62	106	104.5	24.1	0
1.61	760	24.8	2.38	3.86	2.21	106	104.5	24.8	0
2.83	800	24.8	2.38	3.83	3.42	106	104.5	24.8	0
4.05	1600	68.4	6.12	24.36	4.65	125.6	123.9	57.9	0
5.26	1560	60.2	5.1	18.5	6.25	137.6	135.8	56.4	0
6.86	2160	68.4	6.12	31.53	7.47	189.5	188.1	72.9	0
8.07	3160	66.2	6.12	40.61	8.66	191.7	197	58.6	0
9.27	3120	15	1.7	5.75	9.89	143.6	141.8	66.2	86.7
10.88	1840	91.7	8.84	34.78	11.49	156.4	155.2	105.3	95.3
12.09	2240	121.8	11.56	56.39	12.69	187.2	185.1	138.3	95.3
13.31	2720	171.4	16.66	103.19	14.31	191.7	195.5	191.7	83.5
14.91	3760	191.7	20.74	146.08	15.52	191.7	200	191.7	87.5
16.12	4480	191.7	20.4	170.69	16.72	191.7	201.5	191.7	94.9
17.73	5400	189.5	19.04	187.25	18.73	191.7	195.5	175.2	95.3
19.34	6080	172.2	17.68	197.81	19.93	188	186.6	166.2	95.3
20.54	6520	163.2	17	198.92	21.15	188.7	186.6	12.8	0
21.75	5240	14.3	1.7	10.36	22.34	191.7	200	11.3	0
Code:
0	760	3.61	2.4	4.5 B	0.58	0	0	0	0
1.31	1320	14.39	9.8	21.0 B	1.9	0	0	0	0
2.62	1320	22.42	58.8	14.3 B	3.21	0	0	0	0
3.92	3000	63.22	29.8	26.3 B	4.51	0	0	0	0
5.23	2560	38.39	23.5	28.5 B	5.93	0	0	0	0
6.65	1880	39.67	84.7	11.3 B	7.33	0	0	0	0
8.05	2400	68.58	97.6	11.3 B	8.74	0	0	0	0
9.36	3200	121.44	100	1.5 B	10.05	0	0	0	0
10.76	4120	165.31	100	5.3 B	11.38	2.3	1.5	0	0
11.95	4880	186	100	10.5 B	12.67	4.5	3.8	3	3
13.29	5520	193.08	100	9.8 B	13.88	4.5	3.8	3	3
14.61	6080	200.06	99.6	12.0 B	15.29	3.8	3	2.3	2.3
15.9	6560	199.72	100	12.8 B	16.52	0	0	0	0
17.21	4760	12.67	9	3.8 B	17.9	0	0	0	0
Code:
0	800	3.56	2.4	3.0 B	0.61	0	0	0	0
1.22	760	3.58	2.4	5.3 B	1.8	0	0	0	0
2.44	760	3.5	2.4	4.5 B	3.02	0	0	0	0
3.64	800	3.5	2.4	2.3 B	4.23	0	0	0	0
4.84	1600	23.86	59.2	14.3 B	5.45	0	0	0	0
6.07	1400	18.36	12.9	19.5 B	7.04	0	0	0	0
7.68	2360	39.58	23.9	23.3 B	8.66	0	0	0	0
9.27	3360	5.81	5.5	1.5 A	9.86	0	0	0	0
10.49	1640	14.03	9.4	27.0 B	11.49	0	0	0	0
12.1	1880	36.45	85.5	12.0 B	12.7	0	0	0	0
13.31	2280	59	94.9	10.5 B	14.29	0	0	0	0
14.92	3120	127.03	100	3.0 B	15.51	0	3	0	0
16.1	3920	146.97	100	6.0 B	16.71	0	3	0	0
17.33	4640	176.61	100	9.0 B	18.33	3	2.3	3	3
18.94	5560	189.97	100	12.0 B	19.54	3	0.8	2.3	2.3
20.14	6080	198.42	99.6	12.0 B	20.75	2.3	0.8	2.3	2.3
21.34	6520	199.72	100	15.8 B	21.93	2.3	0	1.5	1.5
22.56	5600	9.22	9	5.3 B	23.16	0	0	0	0
Code:
0	1640	35.3	980	990	0.7	1.016	1
1.4	1240	70.7	1160	1000	2.01	0.922	1
2.61	2680	106	1520	1250	3.23	1	1
3.93	2600	48.9	1560	1010	4.61	0.914	1
5.21	2040	109.8	2030	1320	5.81	0.914	0.906
6.44	2560	152.6	2290	1830	7.03	0.922	0.899
7.64	3360	191.7	2340	2270	8.33	0.883	0.875
8.96	4240	191.7	2430	2420	9.63	0.86	0.844
10.24	5080	191.7	2370	2290	10.85	0.836	0.836
11.46	5720	185	2290	2150	12.04	0.813	0.836
12.69	6240	171.4	2160	2040	13.38	0.828	0.836
13.98	6560	54.9	980	2490	14.7	0.828	0.93
15.38	4480	12	980	1050	16.08	1.991	1.047
Code:
0	800	30	0	970	0.71	0.8	-5.5
1.39	800	30	0	970	2.08	0.8	-5.5
2.72	1320	29	0	1060	3.32	0.8	-5.5
3.94	1800	26	0	1150	4.52	0.8	-5.5
5.14	2840	24	0	1260	5.73	0.8	-5.5
6.34	1440	24	76.1	1040	6.94	0.8	-5.5
7.65	1680	23	95.3	1160	8.35	0.8	-5.5
8.94	2040	21	95.3	1350	9.54	0.8	-5.5
10.17	2520	21	95.3	1750	10.75	0.8	-5.5
11.39	3240	20	81.6	2320	12.05	0.8	-5.5
12.69	4160	20	85.9	2420	13.27	0.8	-5.5
13.89	4560	19	0	1700	14.58	0.8	-5.5
15.2	4400	21	0	1040	15.79	0.8	-5.5
16.4	4000	24	0	1020	17	0.8	-5.5
17.73	3480	25	0	1010	18.29	0.8	-5.5
18.91	3280	26	0	1000	19.6	0.8	-5.5
20.21	3200	26	95.3	1010	20.82	0.8	-5.5
21.46	3760	24	84.7	2490	22.13	0.8	-5.5
22.75	4640	21	94.1	2370	23.44	0.8	-5.5
24.15	5400	21	94.1	2180	24.74	0.8	-5.5
25.37	5960	22	90.6	2140	26.05	0.8	-5.5
26.67	6440	23	95.3	2050	27.37	0.8	-5.5
28.08	5560	23	0	1160	28.75	0.8	-5.5
Code:
0	760	34	0	970	0.6	0.4	-5.5
1.19	760	34	0	970	1.78	0.4	-5.5
2.42	1880	33	0	1000	3.41	0.4	-5.5
4.04	1280	31	0	1110	5.03	0.4	-5.5
5.64	2960	29	95.3	1260	6.63	0.4	-5.5
7.25	1600	27	95.3	1050	7.85	0.4	-5.5
8.44	2000	26	95.3	1240	9.05	0.4	-5.5
9.65	2480	24	95.3	1610	10.26	0.4	-5.5
10.87	3160	24	80	2450	11.45	0.4	-5.5
12.07	3960	22	86.3	2410	12.67	0.4	-5.5
13.27	4760	22	95.3	2330	13.87	0.4	-5.5
14.49	5440	23	90.6	2160	15.09	0.4	-5.5
15.69	6000	24	95.3	2080	16.3	0.4	-5.5
16.91	6480	24	92.5	2020	17.51	0.4	-5.5
18.13	5680	24	0	1230	19.11	0.4	-5.5
Damoegan
Oct 15, 2007
8,993
Newcastle
Inlet temps are fine, as are cf's but its not making the requested boost. Its also chucking in a little fuel after 5720rpm, but nothing to worry about.
Damoegan
Oct 15, 2007
8,993
Newcastle
Could be a boost leak....
Block 031 gives you actual rueling and requested fueling, lambda x 14.7 to get AFR.
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Hi Damoegan,
I did a log as below, i only logged 115 so i could get a better sample rate, Is it requested in the first column and actual in the second, if so i am not making requested boost from about 4040rpm on :confused:
Code:
	Group A:	'115
	10.45	2080	111.3	2140	1340
	10.86	2240	118.8	2270	1430
	11.26	2400	126.3	2270	1550
	11.67	2560	139.8	2290	1690
	12.09	2760	157.1	2300	1920
	12.45	2960	186.5	2300	2280
	12.86	3280	191.7	2340	2410
	13.26	3520	191.7	2400	2310
	13.66	3800	191.7	2420	2430
	14.07	4040	191.7	2450	2400
	14.47	4280	191.7	2440	2420
	14.88	4520	191.7	2440	2400
	15.29	4760	191.7	2410	2340
	15.7	4960	191.7	2390	2240
	16.08	5200	191.7	2370	2180
	16.48	5400	191.7	2350	2120
	16.89	5600	178.9	2330	2150
	17.29	5760	175.2	2300	2160
	17.71	5920	170.7	2250	2120
	18.13	6080	172.9	2220	2020
	18.5	6240	163.2	2190	2090
	18.92	6400	157.9	2160	2100
	19.31	6520	163.2	2130	2030
	19.73	6680	154.1	2100	2040
	20.12	6760	163.2	2080	2020
	20.51	6320	12.8	980	1650
harty190486
POWER!!!
Dec 29, 2008
349
staffordshire
id say your boost looks fine mate all the stage 1 logs i have seen including my new map dont meet the requested after 5500 rpm the stock tubby with no down pipe etc eill only really hold 1.0-1.1 bar after that point to the red line it meets the requested till that point so i wouldnt worry mate the only way of meeting the requested after 5500 is down pipe race cat and uprated actuator
