High pitched noise around climate control panel
zephead
Hi Guys,
I made a 3 hour run to Newbury in my K1 on Monday and towards the end of the journey, I noticed a high pitched noise inside the car which seemed to be coming from around climate control panel/media centre. I'm sure that I've not heard it before.
At first I thought that it might be the CC fan but I switched off the unit and the noise remained. I don't think it's the cooling fan either because it doesn't seem to be coming from the engine bay but I could be wrong. It was apparent again yesterday, once more towards the end of my return journey.
Can anyone shed any light?
Many thanks in advance for any advice,
Keith.
duncanross
I had this problem also and couldn't work out what it was.
Eventually worked out that although the air vents around the centre console were closed, they must have a very small opening still which allows a small stream of air through, the air coming through this small space is probably the high pitched noise that you are hearing.
