High Pressure Sensor (G65) fault
technician27
Hi everyone,
I was wondering if someone could help me with finding where High Pressure Sensor (G65) is placed on Seat Ibiza MK4 1.4 16V petrol car. I ran VCDS and logged below error. Also will this cause my car to fail the MOT?
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6L0 820 045 C
Component: Klimaanlage 00.9
VCID: 285F9E85C8228801A7-5140
1 Fault Found:
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
Speed-FReek
1,108
17
South Oxfordshire, UK
The location of the High Pressure Sender (G65) on a SEAT Ibiza Mk4 is item #4 in the following diagram...
And a close-up here...
Speed-FReek
1,108
17
Forgot to add that the air conditioning system is not considered a critical component or safety system in the car and as such, if anything is wrong with it then it won't cause your car to fail the MOT. So you can leave it broken and your car will pass the MOT just fine (unless there is something else wrong with your car that is deemed to be an MOT failure).
technician27
Thank​you for the information very helpful. I think it is this one but I couldn't unplug it, tried to pull the black plastic part first but no luck. ibb.co/bt3A5k
Speed-FReek
1,108
17
Yes, that's the one.
On the side of the connector is a catch. You need to push on the connector as if you are trying to push it harder onto the sensor, then pull back on the catch back with your thumb, and while still holding the catch back, pull the connector off the sensor.
And this is a close-up of your connector from the picture you posted a link to...
You can see how a demonstration of it being done in the following video which shows a larger version of the same type of connector. The actual point of interest is 40 seconds into the video...
Just one important thing to point out. Whatever you do, don't just go unscrewing that sensor because it's plugged into a highly pressurised system. If you're considering changing that sensor then get an automotive aircon specialist out to degas and depressurise the system first. They will also dispose of the gas in a legal and environmentally friendly way. Then change the pressure switch, then get the system re-gassed.
technician27
That's what I wasn't sure about so I was thinking of buy the genuine part (if I can find the part number and supplier) and then take it to local AC specialist garage to get it replaced and get air-condition done. Just trying to find out what the part number is.
RUM4MO
7,824
1,000
South Scotland
I was under the impression that on all VW Group cars, that switch is mounted into a selfsealing valve assembly, so if it gets removed will should just get a short "flash off" as a small amount of liquid/gas escapes, ie unscrew it quickly to minimise gas loss.
I'm willing to be shot down on this though, but if you look at the lump welded to that section of pipe, it should look like it is a bit more than an adaptor to screw a male threaded sensor/biswitch to a pipe.
Edit:- if you are concerned about getting your hand frosted, wear rubber glove!
Speed-FReek
1,108
17
You might well be right. I've never tried removing any aircon sensors on a VAG car. It would actually make sense for the design to be such that you don't have to de-gas and re-gas a system just to replace a sensor. I'm only going on past experience of other makes.
If someone can say for definite that there is a self-sealing valve in the pipe then it will be a safe enough DIY job, but if there are any doubts, better to play it safe and just call in a specialist.
RUM4MO
7,824
1,000
South Scotland
Oh yes, but I should say that as I am lucky enough to have hold F Gas certification to work on any size of systems! Not got any use for that now that I'm retired, but maybe handy to have?
Edit:- great fore sight by VW Group if they have included a one way valve at that point as they do seem to have a lot of trouble with these valves across all their marques!
Speed-FReek
1,108
17
Looking at the exploded parts diagram below, there is an item shown (#37) which is not listed as a part you can buy separately. I appears that you only get that part with the complete pipe assembly (#7). It could well be that this item is the valve you are talking about.
Item #14 is the G65 High Pressure Sensor.
