Ibiza Cupra MAF Sensor
Jonzy
Finally got vagcom working, only 3 codes stored thankfully. Sort of 1/2 expected this one relating to the MAF sensor, just want to double check before I buy another MAF
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
Logged the airflow and at best it showing 79g/s ... this is a standard 156hp cupra so i'm expecting about 120g/s according to the rosstech guides.
Clearing the code, you can actually hear the car idle much better and smoother and
generally feels alot quicker.
Safe to say the MAF is def on its way out?
Jonzy
Nope, ill try that in the morning. I did one when I had the car first and it didnt appear to make any difference to the running.
Once thing I have just discovered, I click the 'readiness' button. All the fields were green/ok apart from the o2 sensor/cat/2nd'ry air sensor ones.... is this something to be worried about?
davidol
New ghetto whip :)
Aug 17, 2004
1,978
Cardiff
jonzy any chance you could vag-com mine too mate when u get 5mins, I think my MAF may also be on its way out and i want to confirm it before i go ahead and REVO the ****er ;)
Jonzy
Martyn, nope will be off to the stealers first thing tmrw to get a new maf.
David: still need vagcom fella?
