Ibiza cupra pd160 hot & cold start issues
Tommeyk
Hi guys, new to this forum. Looking for some help with my car
Looking for some advice / help please
Ibiza cupra pd160
Cold mornings it takes a while to start and when it does it's smokey, white smoke. Sort of sounds like it's hunting once started for a second or two.
When it's at running temp, when the engine is hot, it is also very hard to start but no smoke will come out
Also get very very poor MPG - 28 is the most I've ever seen.
I've just done a one mile drive, went to the shop and then started it again and no problems at all
Already changed the cam position sensor and the fuel filter and this has made no difference at all
Any advice would be appreciated, thanks
Scotty33
18
I would change the coolant temp sensor. Or preferably hook up vcds and see what value it is reading first.
Sent from my E6853 using Tapatalk
Scotty33
18
You may also have a thermostat problem, if this is stuck open, the coolant won't warm up. Best economy is obtained via ecu settings when the coolant reaches 88 deg C.
I guess other possibilities are a bad remap or tuning box fitted?
cheshire cat
1,813
cheshire
vag com is best place to start also a check on the plugs for continuity and if you can manage a vag-com(vcds) live data on start to hot to see what the engine (ECU) sees should be a smooth ramp up of temp I would also take a peep at the egr/intake for gunk assuming the servicing is up to date (take on one's word for it :) )
