Indicators Flash Fast! owt to worry about?
didsi
I Want an LCR!
Aug 25, 2006
123
Its only happened twice since i got the car about 2 months ago but it worries me!!
i was driving and indicating to change lanes and the indicator light on dash and noise was really fast (couldnt see if the lights were any faster) i turned them off and they have been fine since. But it happened again today while sat at traffic lights, i turned them of and on and they are fine. Is this owt to worry about?
Also does putting a subwoofer in void the waranty! just incase i need to take it to garage to fix lights
thanx
didsi
I Want an LCR!
Aug 25, 2006
123
how come it only does it now and again? cud it be a loose connection with bulb rarther than bulb out
Brucel
334
Sheffield
It could definitely be a loose connection or a bulb that is not quite fitted properly?
When it next does it stop and take a look round and see which bulb is not flashing that should get you started on the diagnostic trail... :) good luck in finding the problem.
BEOWULF
I am BEOWULF !!!
Mar 18, 2006
1,186
I AM IN FRONT OF YOU
what i would do is stick ya a hazards on to c if u can c which one is not working or if that fails replace them all like u say if it does it now and again u have 6 to chose from
and for how much they cost u mights as well replace them all
Gaz-04
63
East Midlands
Brucel, Had this myself over the weekend. Front nearside bulb not flashing, I intailly thought blown bulb. Once id managed to take it out I tested it with DMM, bulb not blown so reconnected it to wiring harness and tried it again worked ok:shrug: Assume it must just have been i dodgy connection within the plug coupler. Not a bad job to do just need small hands to reach in the gap to extract bulb holder.
Hope this helps
TheOtherSimon
454
If the indicators flash at double speed - then that signifies a blown bulb.
If they flash REALLY fast then your indicator relay is on the way out. It's actually fitted inside the switch in the dashboard, and die frequently. VW did a recall in the US, but not over here.
You need a 1M0 941 509 B from a Seat delaer - abut £35. Or you can buy the same part from VW (1J0 953 235 J) for £25.
Simon.
didsi
I Want an LCR!
Aug 25, 2006
123
thanx all, that has put my mind at rest! i thort it was gunna be summat major :D
willcooke
Brrrummmm
May 31, 2005
114
Beds
It's a common fault, the springy metal at the bottom of the bulb holder get less springy over time. You could either buy a new bulb holder to stop it happening, or do what I did, and just prise the springy bits up so the push back against the bulb more and make a better connection.
didsi
I Want an LCR!
Aug 25, 2006
123
Thanx for the advice, it happened again after i left work and stayed flashing fast so i got out and the front right indicator wasnt working, i went to halfords and got a new bulb and now it works fine. thanx all
