No bluetooth option in ibiza 2016 media system
Feb 11, 2024
Hello, im sorry for my bad English
I have a seat ibiza 2016 and I always had the bluetooth option when i open my media option
Now there is no bluetooth or usb option, only sd card that I dont use
I've tried to reset the system by holding down the power button, i've done factory reset for media and system in the "setup" but nothing helps.
Thank you:)
Feb 1, 2024
Hey there! No need to apologize for your English—it's totally fine! 😊 It seems like you're facing an issue with your Seat Ibiza 2016's media system. It's a bit odd that the Bluetooth and USB options disappeared, right? You've already tried some troubleshooting steps like holding down the power button and doing a factory reset, but no luck so far.
If those steps didn't work, you might want to check if there's a software update available for your car's media system. Sometimes, a simple update can fix these glitches. You can usually find this option in the system settings. If that doesn't work, it might be a good idea to reach out to the car dealership or the manufacturer's customer support for more specific guidance tailored to your car model.
