possible best mod eveeeer
bigbadjay
1,670
26
North Manchester
Best possible mod eveeeer! Glad it was warm when you took the plunge! your a credit to this thread myman
Just a quick question tim, were the replacement struts long enough/similar to the oem ones?
LeonCR
2,389
they seem based in Northampton so i think i'll just go pick a couple up tomorrow :)
I shall have a chat with them to about a group buy type thing
Daveb77
287
11
Okay everyone, someone had to take the plunge and the water is lovely and warm.
The struts from the Octavia work perfectly. The ones I used were 1U6 827 550F. Nothing else required, the OEM ball pins and rubber stops don't need to be changed. Cost on the Internet was £40 including postage. Video link below
This is on a FL Leon where the struts are 515mm long (tip to tip) or 495mm (centre of ball cup to ball cup). The pre FL uses different OEM struts and I don't know the length of them.
Quality work boss. One daft question though, does this mod make the tailgate harder to close? I.e. need to hang onto the boot to close???
Sorry for being a dingbat!!!
D
LeonCR
2,389
Right done a little bit of research
The forces are as follows
1U6827550F Eject Force [N] = 515
1U6827550E Eject Force [N] = 500
1U6827550G Eject Force [N]= 550
1U6827550H Eject Force [N] = 565
all have a length of = 492mm
Aug 20, 2010
495
Gosport. Hampshire
Mine will fly open then lol good work mate
LeonCR
2,389
1P0827550 that's what on my Leon at the moment apparently has Eject Force [N] of 320
TimSawf
865
South Manchester
Had a slight hiccup this morning. When I tried to pop the tailgate, it was reluctant to open, it opened about an inch then hesitated. What I didn't realise was yesterday it was nice and warm, about 20C, whereas this morning, it was about 8C. I wonder if the temperature is having an affect on the gas pressure.
The rubber stop buffers are adjustable so I just lengthened them a little. Before I adjusted them, it struggled but afterwards, it popped straight open. Only lengthened them a little, to about 35mm from the bodywork. Possibly just enough to give it a little extra push to get started.
Just wondering whether the 550G or 550H may be more suitable, not sure if the extra resistance on closing may cause a problem.
Irfan
Nice job with the pressures.
LeonCR
2,389
Right guys went to Stutsdirect today and had a word with the boss
He has said if you order via http://www.metrol.com/ on the phone then he will do the 515n sturts @ 12.72 + VAT
now this is the same company as struts direct
We fitted a set to Andys car and mate a slight change to make them fit better part number you need to give it NS-FF-8-200 515N B3SA B3SA
Now these seem to work great but sometimes doesn't open but then again we haven't fitted any other parts so thinking getting the bumpers should sort this out
AndrewJB
Aug 16, 2007
11,210
484
Maranello
as Irfan says,
I now have NS-FF-8-200 515N fitted with B3SA ends on and my boot opens! Only thing is i need to get the Scirroco bump stops for it now as sometimes it wont quite open unless you just lift it clear of the latch
Basically it needs some help to the point where the struts take over
My boot has the BTCC Spoiler aswell so is quite heavy
TimSawf
865
South Manchester
Been playing about with mine during the day, seeing if different positioning on the bumpers etc made any difference.
What I noticed was that if the tailgate remained closed for an hour or so, it always struggled to open the first time. After that, it opens everytime, no problem. It's almost as if the strut, having been compressed for an hour, has difficulty reaching maximum force. Once it's been extended once, the tailgate opens fully time after time.
Even when it doesn't fully open, it still opens a couple of inches, only needs a touch with one finger to help it on it's way. Still a lot better than the OEM struts.
