Seat leon 1.9 tdi dpf
Leon1PSilver
16
Hello guys i have a question, seat leon mk2 1.9 tdi dpf do u think the dpf should be turned off by software what are the pros and cons? Any negative, any experience shared i will appreciate.Im pretty annoyed by having regeneration every 200-300km and having the dpf light coming on the dashboard
R3k1355
1,787
251
Yorkshire
The DPF needs to be physically removed before it can be disabled in the software, otherwise it'll just block up.
You can get cleaning sprays to put on the DPF, cheap and quick solution to one thats regenerating lots.
Reactions: Leon1PSilver
Leon1PSilver
16
If i remove it physically will it have negative effect to my engine ?
Do u think cleaning with sprays is better than actually removing it? And will the sprays lower the regeneration, like will it happen less times than on every 200-300?
