Hi All
I am new to the forum so apologies if this is has been discussed before but i am going to change the lower dogbone engine mount. I have a seat leon 1p1 1.6 TDI 2011 and have purchased all new bolts
3x for the dogbone mount
4x new subframe bolts
3 x steering rack bolts
4 x anti roll bar bolts.
I need to drop the subframe so i can replace the engine mount. (I'm sure your aware) I wanted to torque the above bolts to all the correct recommended specs. I was told the sub frame bolts need to be torqued to 100 nm. Does this sounds correct and also does anyone know what the above bolt specs should be.
Any help would be much appreciated.
Thank you for any help in advance.
