Hi all
Old returning member after finally changing car!
Had my MK 2 Sport TDI for 15yrs and 170k miles but finally had to say goodbye to her . Enjoyed every mile but happy with the new upgrade!
Recently picked up 2017 facelift FR with about 60k on the clock and currently having some things sorted and would welcome any thoughts.
1. When bought, the infotainment unit in glovebox had been damaged with a CD stuck in the slot. Garage had sourced a replacement but hadn't coded yet. As I had driven 3hrs to view the car, they offered that I could take it and have it coded locally and they would cover cost which was a bonus! So for 3wks waiting for the earliest slot available, I had limited use and no radio/music!! Picked up after it was coded and radio now works but have lost more functionality!
I'm not exactly sure which version of the infotainment system I have but the head unit appears to be the larger alternative with only two selection buttons and a single dial.
It's booked in again for this Tuesday for them to try and fix but wanted to see if anyone has any ideas about why this coding of infotainment system has lost these features. I don't think the replacement infotainment system was a new one and may have been sourced from another car. Would this make a difference and would it only have whatever features were available on the donor car or is the functionality available?
Other than this I'm loving the car and have it booked in for a Superchips remap at end of month which I had on the old car for about 12years and hoping makes the same difference as before!!
Really grateful of any thoughts and any other recommendations for this model.
Shadders
- Sat Nav menu now shows 'The navigation data in the infotainment system is not valid. Please check data'. This was working fine before.
- Compass on dashboard now only appears intermittently but may be linked to above?
- Bluetooth - Was working but now shows 'Unable to switch on Bluetooth'.
- Android Play - Again was working but now get a line saying something about needing a licence.
- Mode button - Didn't work initially and still nothing. Button lights yellow when pressed but does not bring up mode screen to select. Have seen a previous post by R1chy99 mentioning some code that needs to be reset which will hopefully remedy.
Shadders
