things i had to (you might have to) bear in mind....
1. the factory plastic speaker mount basically gives you an extra inch of clearance from the window. if you mount directly to door make sure the magnets clear the window.
2. if you make mdf rings to get round the above, and the electric window motor gets in the way of the ring, you might have to file off a chunk, or even cut off part of the window motor plastic mounting
