Water Leaking through bonnet release
toshvmax
19
So, Only had my car for a week, a 2019 Leon cupra 300 estate, we had heavy rain last night and the passenger footwell is wet, appears to be coming in just above the bonnet release, any ideas!????
cheers in advance!
SteveGSXR600K1
579
189
Do you have a sunnroof? Use the search function at the top of the forum page as all the possibilities for leaking footwells have been raised before.
toshvmax
19
Hi, Yes, the car has a sunroof, I did do a search and there were a lot of threads regarding sunroof drains, also had a look on Youtube, it seems to be a common issue.... I will have a go at clearing them when it stops raining! thank you for your reply.
toshvmax
19
Well, An update, I braved the shite weather and discovered that the passenger side sunroof drain was blocked, when I removed the little red disc from the end of the drain water gushed out, fingers crossed this fixes the leak!
Reactions: SteveGSXR600K1
Walone
1,559
429
Near Heathrow
It might be an idea, to stop future problems, if the leak is cured, to dry the electrics out that are situated behind the panel where the bonnet release is located.
toshvmax
19
I did think about doing that.
Am I right in thinking that the panel just pops off?
SteveGSXR600K1
579
189
If you have your car serviced with SEAT, they would add a panroof service every 2 years. I've not got one, but have read they change alot extra for this!
toshvmax
19
The car has got a full SEAT service history, and In true dealer style, they clearly hadn't carried out the Panroof service....surprise surprise!
I'll do it myself from now on, at least I know it'll be done properly!
