Home / Store
- Description
Our Premium CUPRA Logo valve caps are made from the highest quality lightweight anodised aluminium with a leak-proof seal. They feature a 10mm CUPRA logo in copper (2mm larger than our standard caps), which is inlaid into the circular-shaped cap. The caps featured a knurled design.
Price includes delivery to the UK
Care and application guide
We recommend removing the caps before washing with any harsh chemicals you plan to use to clean the wheels. We also recommend ensuring any road salt is washed off in the winter.
As a precaution, we recommend applying a small amount of silicone grease to the tyre valve before fitting, and it is generally good practice for your tyre valves. Check the box above to add some to your order.
