Sunstrips on :)
Wheels should be back from powder coating this week :)
Did you put strip on in the inside?
Had mine done by a tint place couple years ago & mine kept coming off
Chap blamed the design of the window & gave me my money back lol
Looking sweet. When did u do the single wiper conversion I can't remember seeing it in your thread?
Also what colour have you gone for on the wheels?
Sean's Xperia arc
On the outside :) i used to fitted at a motorfactor i worked at for 15quid so done a few haha
Whats your roof lining like now you painted it mucka? Is it all rough?
Sean's Xperia arc
Storm wipers mate from tweaks. Its near the front of my thread :)
Silver with metal flake in :)
Yeh all painted with suede extra's
Roof liner is rough yeh but getting it covered in suede now along with door card's as it feels soooo good mate lol
Looking to update my rr once im all mapped up & running
Would that be a bam crank or q forged crank outa another 1.8t.
Or are you going all out and fitting a 2.0l tfsi crank to make a stroker engine?
Sean's Xperia arc
Few pics of the engine being stripped down a bit more
The only bit of wear ive found so far was the relay roller on the hyrdaulic damper had bit of play and the drive belt tensioner had play in the rollers bearing too.
The waterpump had no gasket fitted either? Sure the ones i sell at work do.
Pic of the sensors so i know which went where lol
Oil housing cooler etc off
Coolant line off
Lots of stuff thst needs labeling
Gunna take coiles and rocker off tonight. Will probs also test fit the Relentless manifold.
What kind of spec are you building the engine to mate? My plan is to garage it and build and engine this winter.
I was only going 1.9 with some 83mm pistons but this 2.0TSFI crank out of a 2012 S3 came up from a mate that i couldnt refuse haha. Havent deicded on engine spec 100% tbh once my Ring trip and my holiday is out the way ill set my wish list in stone.
What you planning? I brought and a spare engine rather than taking mine off the road so i didnt get bored and break the car half way through the build.
Test fitted the Relentless manifold tonight. My god theres one nut that looks impossible to get on the stud let alone do it up. Lol
As you can see the first exhaust tube on the left i hiding the top nut nicely and you cnt see it from above because of the head.
Few pics of it on
Rocker cover off aswell to check my head bolt tool was long enough
And it is :)
Sump off next to look in there, then head off :)
Nice work bud. Have fun with that manifold nut, I tied it onto a piece of fishing wire and just had to wiggle it til it went on properly, then just cut the wire and let it melt away. Fiddly job.
