If I've understood it correctly, the Ibiza doesn't have a separate bearing and hub, and instead has an integrated bearing/hub assembly.
So now my rear bearing is gone I need to buy a new assembly, undo the bolts from the old one, replace and tighten it all up again (also removing brakes etc that are in the way...)
I don't need a15t press to get the old bearing out/new one in and in theory, with a bit of patience and enough force to undo the bolts it's a DIY job?
SEAT want £108 for the bearing, or £250 for fitted.
A hub assembly is about £50 on eBay, so if it's something that can be done myself on my drive I'd rather save the money!
I'm not really a mechanic-y person, but I can follow instructions and have a modicum of common sense.
