Good to know I suspect VCDS may prove to slowly become obsolete as it is increasing doing less and less on newer vag group cars. OBD11 and VAG can pro are taking over.
Not having driven the new Ibiza, but in most other modern SEATS, if your car is a manual the armrest just gets in the way of gearchanges - not to mention the handbrake. With DSG it would be OK but all of mine have been manuals and the armrest stays stowed in the vertical position at all times.
Waste of money and effort.
RE ERWIN: register online free (link on this page)
https://erwin.seat.com/erwin/showInfoTour.do
Then you can see what you need and pay for download access.
Thanks this is a good diagram, looks like it may be more complex to fit/remove as sees to bolt through the floor pan. I’ll see if I can get a chance to have a look at mine tomorrow/Monday. Though I appear to only have access to bolts (2) above.
Not sure if it will make a difference but from what I’ve seen the new polo uses the same armrest/fittings, not sure if could be sourced from VW instead?
new Polo SE it’s £135 as an option
