LeylandVCDS
630
387
Leyland, Lancashire
I've seen from other posts that the Golf 7 carpet wheel well liner, part number 5G6863007D or5G6863007E has been installed by some members on here. But I 've only seen this related to the Leon 3 hatch.......can anyone confirm if either this part fits the ST Estate, or if not, if there is a similar liner that does fit the estate, with a relevant part number please.
Wanted for a facelift ST estate, 2019 19 plate.
Many thanks
5F9 863 463
have installed this number.
This is the correct part number for the Leon ST.
Don't fit 5F9863463A as that is for the gas drive system and is a different shape.
You could use 5G9863544B (Mk7 Golf estate floor cover) but won't fit exactly as the proper Leon ST one but it's pretty close!
Reactions: LeylandVCDS
Yep, I ordered the 'non-A' part number as I couldn't find used, however the dealer ordered the 'A' part number which is only a small piece which covers the front section and no wheel well...waiting for the correct part to arrive...it's expensive, but I sound-deadened the boot and want a finished look.
Reactions: Craig.
I'm just getting around to sorting the boot, how did you find the the boot trim fit with the sound deadening in place? Any issues?
Morning Craig,
Hope you’re well buddy, and the car’s all good.
No problems fitting it with the sound deadening, although the little black plastic screw caps on the ends of the ‘hump’ between the seats and front of the boot are on the end of their threads.
Looks great, and very OEM.
Cheers,
Nick
Reactions: Craig.
