Yeah the light is activating but it's not all the time which is confusing me I've also just realised I can't hear the diverter valve opening I had a look at the actuator rod there's a bit of play in it and when I rev the car and let off it's not opening but I'm also not getting surge back through the turbo. And yes the timing belt was done but that was at 100k Kms. I bought the car from a garage so I do have warranty on it but not for long I will be going back to him with it. Should I go to a seat dealer first and ask them to have a quick look?You say two-cylinder more is activating, how do you know? Is the tell-tale light on the dash activating under acceleration? Shouldn't be. It should only activate when the engine is under very low load. As soon as you ask for power it should switch back to four cylinders and you shouldn't feel the transition at all.
I don't know the ins and outs of the system but it's very finely tuned. You need special kit to replace the timing belt and typically only dealers and VAG specialists have it. If an independent garage changed the timing belt assuming it's just like any other car it's possible they didn't get it right and the system is not working correctly. Check the service record. If Joe Blogs changed that belt I think I'd be taking the car to a dealer or VAG specialist to have the ACT system checked.
I would suggest faulty injectors too but I can't see that putting the ACT light on.
The ACT light does come on and off. It just depends when. It should only come on under very light load. As soon as you press the accelerator it should go out.Yeah the light is activating but it's not all the time which is confusing me I've also just realised I can't hear the diverter valve opening I had a look at the actuator rod there's a bit of play in it and when I rev the car and let off it's not opening but I'm also not getting surge back through the turbo. And yes the timing belt was done but that was at 100k Kms. I bought the car from a garage so I do have warranty on it but not for long I will be going back to him with it. Should I go to a seat dealer first and ask them to have a quick look?
Ah grand I'll have a look for one so thanks for the replyThe ACT light does come on and off. It just depends when. It should only come on under very light load. As soon as you press the accelerator it should go out.
The actuator rod on the turbo does have play on it, it's supposed to be like that. They can stick. My son's stuck. Worked some high-temp grease into it and it's been fine since. I don't know if that could cause your symptoms but worth checking.
From my experience, dealers are not very good at fault finding. Anything much outside of routine maintenance and they're stumped. I'd be inclined to trust an independent VAG specialist more.
Yeah, it's a problem as cars get older. Some maintenance tasks become a big chunk of what the car is worth. My wife wants to keep her car, forever I think, so whatever it needs I just get it.I phoned around a few local places and they all want £1k+ for walnut blasting unfortunately, just not worth it at that price.
Did you ever get to the bottom of this? I'm having the exact same problem on my 2015 ST with the same engine, no eml and no stored or pending codes, revs fine in first gear but stutters when revved over 4000rpm in second gear, haven't tried 3rd gear, there's always somebody in front. Just bought the car 30 days ago from a dealer who haven't been very responsive since I reported it to them a week ago so had my usual garage scan for codes but he couldn't do more without booking it in for next week.Hi lads new here just recently purchased a manual 1.4 Leon FR 2014 having an issue when accelerating hard the power just cuts suddenly at 4k rpm and stutters all the way to 5 two cylinder mode seems to be activating any suggestions on how to stop this
Yeah ended up sorting it self It was just injectors took about 2 bottles of injector cleaner to sort it threw a third one in after just to be sure don't know why the 2 cylinder mode was activating when this was happening but haven't had any problems since no codes for my self either stored on vcds. Id say give the injector cleaner a go and maybe a bottle of dieptainDid you ever get to the bottom of this? I'm having the exact same problem on my 2015 ST with the same engine, no eml and no stored or pending codes, revs fine in first gear but stutters when revved over 4000rpm in second gear, haven't tried 3rd gear, there's always somebody in front. Just bought the car 30 days ago from a dealer who haven't been very responsive since I reported it to them a week ago so had my usual garage scan for codes but he couldn't do more without booking it in for next week.
I may be best trying to find a VAG specialist near to me.
The first thing that comes into my head when I read that is supermarket fuel.Yeah ended up sorting it self It was just injectors took about 2 bottles of injector cleaner to sort it...
Id say your right about that I also think that the car was left sitting for a good while as the tyres on it are quite old and front and backs are the same year so I'd say that didn't help it either not being drivenThe first thing that comes into my head when I read that is supermarket fuel.
Yes, the base fuel is the same but premium fuel contains additive packs which help to keep your fuel system and engine clean. Quality control of the whole process is just tighter. Over the years I've seen so many issues caused by supermarket fuel. They insist it's the same quality as branded fuel but it's not. That's why it's cheaper.
Just last week a friend told me his car's engine light came on immediately after his wife filled the car with supermarket fuel. He went on to his local Facebook group and found that loads of other people in the area were reporting exactly the same thing! My bet would silicone contamination and gubbed O2 sensors.
Yeah, also not good. If nothing else, petrol degrades over time and modern stuff with that ethanol crap in it is worse. Just Run it for a while with good fuel and I think you'll be fine.Id say your right about that I also think that the car was left sitting for a good while..
