Reactions: Syphon
It looks and drives great. Love it to bits even with the few issues I’ve had with it.
Firstly was hit by a lorry on the m25. Came into the side of me and scuffed up the passengers door.
Secondly been having a few electrical problems. Key fob not working on few occasions, windows going up when pressing down and then going down when pressing up. The latest is the wing mirrors have stopped heating so with it being winter now, it’s probably the worst time for that to start happening.
  • Wow
Reactions: Syphon
Thank you for the welcome.
I do have the carbon fibre cover for the key fob. I’ll revert back to the original and see how I get on with that. Shame if it is the cause as it looks great
Reactions: Syphon
I’ve changed the battery on it recently as I thought that might have been causing the issue.
Th problem I’m concerned about mostly is the heated wing mirrors that have stopped working.
Not yet I haven’t. Thought I’d ask in here first to see if anyone else had any similar problems/fixes
Reactions: Syphon
A blown fuse maybe?
If you already didn't, you can try finding the mirror heater fuse location in the user manual and check it.
There isn’t a fuse for the wing mirror. I’ve had a look through the manual a couple of times in case I missed something but I couldn’t find any fuse related to the wing mirror.
It made me wonder if it’s maybe connected to the rear window?
do you have a scanning tool, run that and see if any errors are reported.
On my older car you have to manually select the heated mirror, is that the same on your's either way again if you have a scan tool you should be able to do a output test to ensure its working.
