pillgrim1 Active Member Nov 7, 2009 59 0 Jan 21, 2026 #1 hi will the leon cupra alloys be a straight swop for my diesel fr. its a mk1 cheers
serdar_18fr Active Member May 29, 2021 944 1 698 Jan 21, 2026 #2 pillgrim1 said: hi will the leon cupra alloys be a straight swop for my diesel fr. its a mk1 cheers Click to expand... By "Leon Cupra", which generation do you mean?
serdar_18fr Active Member May 29, 2021 944 1 698 Jan 21, 2026 #4 pillgrim1 said: it will be the same as mine a mk1 05 plate Click to expand... Then there will be no PCD-wise problem. Mk1 uses 5/100, later gens switched to 5/112. What is your current wheel diameter and tire size ? Reactions: SRGTD
pillgrim1 Active Member Nov 7, 2009 59 0 Jan 21, 2026 #5 seems the 05 is actually mk2 and tyres are 205/55R16
SRGTD Active Member May 26, 2014 2,976 1,857 Jan 21, 2026 #6 pillgrim1 said: seems the 05 is actually mk2 and tyres are 205/55R16 Click to expand... If they’re mk2 Leon Cupra alloys then they won’t physically bolt onto the the mk1’s wheel hub assemblies because of the different PCD / bolt pattern. Reactions: serdar_18fr
Syphon Site Owner Staff member Feb 28, 2002 10,543 2,921 South West www.seatcupra.net Jan 22, 2026 #7 Welcome to the community. Cheers, Scott
