Bagpuss12
46
My crankshaft oil seal has gone and needs replacing. I know this is a fairly big job and requires a number of other parts needing to be removed/replaced in the process.
I believe that the current oil seal replacement isn’t great and after all this work, it may well start to leak again in the future?
Does anyone know if there is an after market upgrade for this part, to ensure it won’t leak again once replaced?
Give us a clue, on which engine you are referring to?
Also, how many miles has it done?
It’s a Seat Leon FR on a 2015 plate with the 2 litre 150bhp engine. It’s done 110k miles now
Ok, (presuming you're refering to your front crank seal, and not your rear crank seal?) for the TDI front crank seal you also need to drop the sump, and while you're in there I would also replace your small belt in oil that drives the oil pump.
It's basically a timing belt job + sump removal.
Has it ever had a timing belt?
How bad is the leak? just a weep - or an actual drip?
Don't know why you say it would leak again when a new one is fitted?
Its a ptfe seal, and needs to be fitted DRY - and left a few hours/day before the engine is started, otherwise it may well fail soon after.
Timing belt changed around 18 months ago and yes it’s the front. It’s weeping but means it’s covering the underside of the car etc and means I can’t park on my drive presently
Mine has a slight weep - at 160k miles, but is not enough to make it to the floor.
Its a shame you can't coincide it with a timing belt change.
I've seen people change the front main seal without dropping the sump - but seems a bit of a bodge to me - as its difficult to guarantee the seal in the corner.
